Changed Speedometer Gear...still way off (the other direction!) - JeepForum.com
post #1 of 4 Old 07-02-2013, 11:21 AM Thread Starter
StanF
Changed to 32" tires (BFG ATs) with my stock 4.10 gears, and using the chart here, determined that I needed a 36 tooth gear:
http://www.quadratec.com/jeep_knowle...article-46.htm
Bought one, installed it, but now my Jeep appears to read about 5mph over the correct speed at 65mph. I verified this by driving next to a friends car, and by timing between mile markers. So my speedometer reads 70 when I'm going 65mph. I checked a few other online speedometer charts, and they all seem to say 36 teeth for my situation.
I was a little disappointed, as at first I thought the speedometer gear was some magically performance upgrade!
Has anyone else seen this issue? If 36 isn't the right number, what would be? I hate to keep buying gears!
StanF is offline
post #2 of 4 Old 07-02-2013, 11:29 AM
pasinbuy
Forget trying to check the mph by driving next to your friend or mile markers.
Borrow a GPS and check your mph that way. Then go up or down as needed.
By the chart 36 is right although remember that not all tires are the same in height and changing tires brand to brand may or will throw off the speedometer a bit.
pasinbuy is offline
post #3 of 4 Old 07-02-2013, 01:00 PM
Siva283
^^^^This is the best advice you will get. Alot of 33's for instance are actually 32's
Ask me how I know...
Siva283 is offline
post #4 of 4 Old 07-02-2013, 01:04 PM
rage4order
2015 JK Wrangler
If you have a smartphone, there are speedometer apps, not to mention gps apps.
rage4order is offline
