changed my pinion bearings and seal... - JeepForum.com
post #1 of 4 Old 06-05-2011, 01:41 PM Thread Starter
tysonyj
i changed my pinion bearings and seal... diff is still maken brutal noises.... think the pinion gears are done... does anyone know what the gear ratio is on a stock yj 2.5l ??? i dont know alot about cars but i am learning as im going...im bein nice and she just keeps bein a ***** kinda like how my ex was...
tysonyj is offline
post #2 of 4 Old 06-05-2011, 01:49 PM
brockmarzullo
should be 4.10 gears. Gears are something you dont wanna mess with if you don't know what your doing though. I would never do my own. I dont know enough about them. I would get someone around that does know and learn from them. Or save a lot of hassle with the Turdy5 and swap in a ford explorer 8.8. 1995-2000.
brockmarzullo is offline
post #3 of 4 Old 06-05-2011, 01:55 PM
TheNewbie
Maybe... The 4 cyl YJ's with the 5 speed had 4.10's but if he has an auto tranny then he has 3.73 gearing.
Agreed. Except for the Explorers with disc brakes also ran through 2001. So that's one more year to look for as far as possible donor vehicles. And the earlier 90's Explorers will work, but they just have drum brakes.
BTW, fill out your profile with at least your engine and transmission. This will help you get more replies.
1995 YJ 2.5 - 4 RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
post #4 of 4 Old 06-05-2011, 01:57 PM
brockmarzullo
Ah yes i forgot about the auto's. Thanks for the correction!
Is the Rubicon D44 pinion seal that much different from a TJ D44 pinion seal??? Jerry Bransford TJ Wrangler Technical Forum 1 12-23-2010 06:22 PM
Changed pinion seal, now squeal under hard acceleration ultravorx TJ Wrangler Technical Forum 8 11-01-2009 07:13 PM
D44 rear pinion seal vs. NP231 transfer case seal thejafe TJ Wrangler Technical Forum 14 06-14-2009 01:24 PM
pinion bearings... Xtoyaddict TJ Wrangler Technical Forum 1 04-06-2006 02:27 AM
Locked Dana 30s and Bad Pinion Bearings/Leaky Pinion Seals 97TJGUZZY TJ Wrangler Technical Forum 3 03-15-2006 05:46 AM
