Change a perfectly good RMS when I change the clutch? - JeepForum.com
post #1 of 7 Old 11-30-2006, 02:25 PM Thread Starter
HotDogWater
So my baby needs a new throwout bearing and tranny input shaft. I have about 115k on her now, and I figured I'd put a new clutch in there along with the other 2 items. I'm wondering if I should go about changing the rear main seal as preventative maintenance, sort of "while I'm in there." I don't know how often they start leaking on the 2.5s, but I haven't noticed any leaks from there yet. Whatcha think? The toughest thing I've done so far is replace the exhaust manifold.
95 Rio Grande 2.5L -- stock with 30x9.5 ATs
HotDogWater is offline
post #2 of 7 Old 11-30-2006, 02:30 PM
toomanytoys
I'm not sure about the 4 bangers, but you can do a RMS on a 4.2 from the oil pan. If you can do the 4 cyl as well from there, I'd say let it ride. If you can't do it from the oil pan on the 4, the I think the whole. "ounce of prevention vs. pound of cure" thing applies.
toomanytoys is offline
post #3 of 7 Old 11-30-2006, 02:57 PM
Brown Dog
Vendor
Brown Dog's Avatar
Yeah, it's not the same on the 2.5. I always say that if it's a five buck part that wears and that is hard to get to, and you are looking right at it, change it.
Brown Dog Offroad
Motor Mounts, Motor Mount Lifts (MML), and Engine Brackets for Jeep
100% HANDCRAFTED IN AMERICA
91YJ 2.5
Brown Dog Mounts and Engine Brackets (Serial Number 1)
2" BL
4.5" Superlift SL
AA SYE
35" GoodYear Mud Terrains
Conteract Balancing Beads
Bulldog front bumper
Best Top seats
"Family" roll bar
25 foot 1/2" log chain
No Top, No Doors (Best Top Safari)
Brown Dog is offline
post #4 of 7 Old 11-30-2006, 02:59 PM
toomanytoys
Then definitely change it while you're there.
post #5 of 7 Old 11-30-2006, 03:41 PM
flame0086
115k, that's amazing! My new engine didn't even go 1k before RMS went. Couse, I is was covered under waranty......
And so was the valve cover gasket, the head gasket, the dirty injectors, and the o2 sensor
100 mpg!! Western Washington Univeristy X-Prize Team
Support Search and Rescue
Get Lost
flame0086 is offline
post #6 of 7 Old 11-30-2006, 04:04 PM
JFM626
JFM626's Avatar
If you decide to replace the rear main, be sure to pick up new flywheel bolts.
JFM626 is offline
post #7 of 7 Old 11-30-2006, 05:01 PM Thread Starter
HotDogWater
hmmm thanks for the advice guys. looks like i'll be changing it. just kinda scared to turn a perfectly good rms into a leaky one.
Clutch--To Change or Not budro69 TJ Wrangler Technical Forum 1 10-31-2009 08:39 PM
when to change clutch? roadbosstx TJ Wrangler Technical Forum 7 09-25-2008 02:43 PM
Clutch Change qbert213 TJ Wrangler Technical Forum 3 01-28-2008 05:31 PM
Hard to Change Clutch in '00 TJ? Roman68 TJ Wrangler Technical Forum 6 07-21-2005 01:25 PM
Yj Clutch Change bryanjeep YJ Wrangler Technical Forum 2 07-29-2003 11:50 AM
