chain rattling noise indentification - Page 2 - JeepForum.com
post #16 of 26 Old 11-27-2008, 04:53 PM Thread Starter
90islander
Did the noise your talking about increase with speed?
90islander is offline
post #17 of 26 Old 11-28-2008, 08:39 AM
K4KAS
Seems the noise increases with speed and RPM's are irrelevant. If that's the case then it has to be something in the driveline. When he says it sounds like chain rattle, one persons idea of the sound will be diff than someone else. Is there a better way of describing the noise you are hearing?
K4KAS is offline
post #18 of 26 Old 11-28-2008, 11:32 AM Thread Starter
90islander
The sound of a chain rattling is the best I can describe the noise, maybe the sound of a bad bearing. The noise sounds like it is coming from between the tranny and engine or somewhere in that area.
post #19 of 26 Old 11-28-2008, 11:38 AM
sebastian22
I had a terribly annoying rattle a while back. It drove me crazy for a month until I finally found it. Just turned out to be one of the rods under the passenger seat was loose. I put some zip ties on it and now its all good. You might get lucky and it could be something stupid like this.
95 Black YJ
sebastian22 is offline
post #20 of 26 Old 11-28-2008, 01:48 PM Thread Starter
90islander
I wish it was somthing as simple as that. I checked and nothing under my seat was loose. Could it be something in my transmission? My jeep made this noise before I put the new tranny in.. Is there a bearing that spins when in neutral and when the clutch is engaged. Maybe something in the axle?
post #21 of 26 Old 09-30-2009, 11:48 PM
midnightc2
Hey, I think I have the same issue......!!!!!
Ok, so reguardless of cluch in / clutch out / neutral / in gear I have a clicking that gets louder when my Jeep rolls faster. ( Think about how as a kid, one would put a playing card in the spokes of the wheel to make a cool noise) Only this noise bugs the crap out of me!!! The noise comes from what sounds like somewhere between the transmission and front axles. I just replaced my vacuum hoses to the front axle (because my 4x4 light was stuck on due to lack of vacuum) and also replaced the vacuum switch on the TC ( It wasn't switching the vacuum at the front axle)
I had LesSchwabs check my the u-joints on the front axles (seemed tight), and they checked the axle bearings on the front by shaking the tires (They also seemed good)
I lubed up the front end, checked the front and rear diff. levels , checked the transmission levels and none of that did anything either. ( Didn't check the transfer case level cause I cant find a big enough socket for it, it's huge!)
My daily: 93' Wrangler- 4.0, 5spd AX15(with external slave swap) , NP231j, Dana 30/35 My Toy: 86' CJ7 Renegade
midnightc2 is offline
post #22 of 26 Old 09-30-2009, 11:50 PM
midnightc2
by the way I just bought a 93 Yj 4.o , 5 speed, and I BELIEVE I have the ax-15 trans.......Don't go thinking the above post was for my CJ7
post #23 of 26 Old 10-28-2009, 01:22 AM
midnightc2
Man, sounds like the problem I'm having. Nobody listened to me either. People kept telling me exhaust or engine. They don't seem to understand that it's not engine related...... I can turn my Jeep off and roll it down a hill. As it ROLLs faster the noise gets faster and louder. How can someone say the exhaust might have a leak when the engine isn't even running! The sound seems to be coming from right under the shifter or maybe towards the front diff. Does that sound like your issue?
I rerouted my exhaust, cut out my cat, disconnected my front driveline, changed the fluid in the front differential, replaced my rear yoke and u-joint, had Les Schwab do a full shake down (twice), had a mechanic friend look at it, checked engine and transmission mounts with no change at all. I've since got a nastier sound that I think is clutch/transmission related. I am in the process of installing a used tranny and will check out the cluch while I'm in there. I'll find out if this changes the first sound too when I get it back together. If so I'll let you know, but untill then don't give up on your Jeep!
post #24 of 26 Old 10-28-2009, 09:24 AM
Barrio
U-joints??
-OD Green/Flat Black 92' 4" Rough Country Lift, tons of crap.
-Rio Red 1995 Ford Mustang- Daily Driver
Originally Posted by alfmoney
i see theres a bunch of toughguys on this forum or internet gangstas
Barrio is offline
post #25 of 26 Old 10-28-2009, 10:13 AM
gkainz
I bet it's the transfer case chain... yeah, I know you said it's new(er) but nothing else makes sense as you describe it.
gkainz is offline
post #26 of 26 Old 03-10-2013, 02:31 PM
Dcount7
I'm having the exact same problem too. Did you ever find out what the problem was. Ive searched and searched and havent seen too many promising posts about a solution to it. Most people tell me the same things as you were told.(exhaust, loose linkage, loose bolts) I cant find anything. Pretty sure its not a throw out bearing. Ive read some interesting things though. Broken teeth in rear diff causing a rattle up the drive shaft. Im almost convinced mine is the TC chain. A year ago I had someone install a lift on along with an SYE. The guy that put the lift on subbed out the SYE work to a guy I didnt know. He pulled the whole transfer case and installed it. I was told when they dropped it off the lift, they couldnt get it to stay in gear. He said that the guy took the transfer case off again and "adjusted" it. Im not too familiar with TC's so I just went with it. Ever since then I have heard this noise. For the longest time I thought it was my exhaust because my lift kit that was installed was a long arm so the factory muffler was riding on the UCA and I figured that was the rattle. After getting a muffler shop to install a smaller muffler and hang everything out of the way the sound still continues. I just figure now that if i heard the noise only after the SYE was installed, and I still hear it, that has to be it. Drives fine though and has for some time now. Also took it to 4wheelparts and the guys there claim they dont hear anything. If you figured yours out it would be much appreciated.
Dcount7 is offline
what is this rattling noise wmeyer116 TJ Wrangler Technical Forum 7 11-04-2009 05:07 PM
Rattling Noise nwiTJdave TJ Wrangler Technical Forum 7 10-21-2009 01:24 PM
Rattling Noise Mud-n-Beer YJ Wrangler Technical Forum 27 04-25-2009 01:06 PM
getting a rattling noise rallon YJ Wrangler Technical Forum 4 09-08-2008 07:43 PM
Rattling noise??? TRF TJ Wrangler Technical Forum 3 02-16-2006 11:10 AM
