Centra pod question - JeepForum.com
post #1 of 4 Old 03-19-2012, 09:20 AM Thread Starter
acat
Centra pod question
Looking into getting one of those pods that mount on the floor in front of my shifter. Will it fit if I have the two heat ducts that exit on the tunnel under dash. I've seen pictures of them in jeeps but not with the heat ducts mine has. Also what size speakers can I get in them. Where's the best place to buy this. Thx
acat is offline
post #2 of 4 Old 03-19-2012, 09:42 AM
scubamc
Without us seeing what heat ducts you have it is going to be real hard for anyone to say if they should fit or not. So a picture would help. I think they come cut to fit a 5.25" speaker. You can cut the opening wider to fit a larger speaker. As for where to buy, just google that.
scubamc is offline
post #3 of 4 Old 03-19-2012, 09:52 AM
timatoe
timatoe's Avatar
I've wondered this in the past as well, because I've got the extended duct piece. I believe the pod sits in front of the ducting (toward the rear of the Jeep) and shouldn't interfere, but I don't have first hand knowledge.
timatoe is offline
post #4 of 4 Old 03-19-2012, 10:08 AM
scubamc
From looking at some pics on the internet it looks like they will set far enough away that they should work.
scubamc is offline
Lift/Tires question and Cleaning soft top & engine question Bryan_16 TJ Wrangler Technical Forum 16 05-19-2012 03:25 PM
Tire question(noob question but just a quick answer needed) 07SilverX JK Wrangler Technical Forum 3 12-25-2007 03:35 PM
Centra-pod, mod-pod, sky-pod 91YJSahara YJ Wrangler Technical Forum 7 02-07-2007 10:15 AM
Centra Pod Speakers highway jeeper YJ Wrangler Technical Forum 5 03-04-2002 09:53 PM
