Centering up my 8.8 . - JeepForum.com
 3Likes
  • 1 Post By Jeeps2006
  • 1 Post By StanF
  • 1 Post By Joe Dillard
post #1 of 13 Old 03-10-2016, 10:52 AM Thread Starter
70ssclone
I know there's a billion threads on axle swaps but I just need some quick answers as to what recommendations you would make for accurately measuring to center up my 8.8 explorer rear axle in my Yj . As of now its sitting in the jeep on its own weight for pinion angle but appears the right tire sticks out more so I need to figure this out before tacking .. I read somewhere that if I move the perches 9/16 on each side past the stock 8.8 perch centerline ( 9-15/16 pass and 12-15/16 driver )it will be damn close to the yj mounting centerline
70ssclone is offline
post #2 of 13 Old 03-10-2016, 11:14 AM
Jeeps2006
I centered the drive shaft and put a 1.5" spacer on the passenger side wheel.
YJdothat likes this.
Jeeps2006 is offline
post #3 of 13 Old 03-10-2016, 11:41 AM
Shadownwpa
Center the axle under the jeep. The axle being slightly narrower than the front won't hurt a thing.
To locate the perches on mine I think I measured off the backing plate mount flanges and set them to the same width as on the 35.
http://www.jeepforum.com/forum/f22/shadownwpa-91ish-yj-build-thread-1857154/
Shadownwpa is online now
post #4 of 13 Old 03-10-2016, 11:42 AM
Shadownwpa
Are you serious?
post #5 of 13 Old 03-10-2016, 12:20 PM
Sprungover
There was just a thread on this exact topic. Center the axle.
please post some pics
1989 YJ, 1977 CJ-7
Sprungover is offline
post #6 of 13 Old 03-10-2016, 12:23 PM
StanF
+1
This is the correct way.
Don't overthink the process. It's pretty easy.
paulhead likes this.
StanF is offline
post #7 of 13 Old 03-10-2016, 12:41 PM Thread Starter
70ssclone
Originally Posted by StanF View Post
+1
Thanks for the insight stan, and everyone else il post up later tonight when I get it figured out
post #8 of 13 Old 03-10-2016, 02:36 PM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
I've seen no one else do this (zero), and no one is having problems with the pinion off to the pass side as it ends up. I'm not saying you should change anything (well, maybe I am, since it's way better than a plan needing a spacer forever). I'm just letting the OP know it's very unnecessary.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #9 of 13 Old 03-10-2016, 04:31 PM Thread Starter
70ssclone
Thanks , about to tack it up , used a plumb bob from the frame and measured from the flange on the axle , I was only about 1/8 off , not enough to mess with it .
post #10 of 13 Old 03-11-2016, 03:20 AM
Feetwet
Enjoying the Ride
Feetwet's Avatar
Your final measurement should be 5 1/4" from Inboard the Brake Backing Plate to Outboard Face of spring Perch.
Same for both sides.
Fight Crime...Shoot Back
Friends don't let friends roll over without a negative-G strap
Feetwet is online now
post #11 of 13 Old 03-11-2016, 06:40 AM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
I prefer using a plum bob.
Randonexplosion likes this.
Joe Dillard is offline
post #12 of 13 Old 03-11-2016, 09:38 AM Thread Starter
70ssclone
After some advice this is what I did , I hung it from the frame ( same hole on both sides ) came up with 5 1/8 on one side and 5 on the other I went ahead and tacked her up after i set it back on the ground and adjusted pinion to 14 degrees and driveshaft to 16
post #13 of 13 Old 03-12-2016, 08:54 AM
RockWoRM
RockWoRM's Avatar
Sounds like you already got the ball rolling.
However... if you had the axle with the factory perch's still on it... it is just a simple measurement off the factory perch's to set the new perch's for a YJ. No need to hang, no need to plum bob, no need to measure off the backing plates. You simply measure outboard 9/16" each side and set your new perch's there. Simple.
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
