CEL question - JeepForum.com
post #1 of 4 Old 04-13-2010, 04:20 PM Thread Starter
msprooch
CEL question
When you turn on the jeep shouldn't the Cel light come on? Mine doesn't but my jeep still runs, not to well but it runs.
I know that the bulb can be bad but I wonder if my computer is dead or a bad fuse.
If this helps my seat belt light works and so does my shift light. I don't know if the ecu controls these or if something else does.
Thanks for the help.
msprooch is offline
post #2 of 4 Old 04-13-2010, 04:24 PM
idaholtby
Yes, The CEL lamp should come on when the ignition is first turned on before going to start. Because your rig still starts, I would guess that a previous owner removed or disabled the lamp to help with it's sale.
idaholtby is offline
post #3 of 4 Old 04-13-2010, 04:28 PM Thread Starter
msprooch
Im the only owner so I didn't do that I will check the light. Thanks for the info.
msprooch is offline
post #4 of 4 Old 04-13-2010, 04:54 PM
idaholtby
I'm the only owner so I didn't do that I will check the light. Thanks for the info.
Pin 32 on the ecm supplies the ground for this lamp. If the bulb or it's contacts are not bad, then chase this signal back to the ecm connector. Frequently when the CEL does not illuminate when the ignition is first turned on, then it is an indication that the ecm is not powering up and the rig will then not start. This scenario is due to bad capacitors in the ecm which is easily fixed, but your rig starts. Does your lamp ever come on, even if you wait a spell before starting?
Lift/Tires question and Cleaning soft top & engine question Bryan_16 TJ Wrangler Technical Forum 16 05-19-2012 03:25 PM
Front sway bar question + bonus disco question WranglerTom TJ Wrangler Technical Forum 7 12-02-2011 08:13 AM
1988 carberator question and wiring (general) question prljeep YJ Wrangler Technical Forum 15 05-08-2009 11:50 AM
quick connecting rod question and tourqe wrench question???? johnrezz YJ Wrangler Technical Forum 2 10-18-2008 07:20 PM
Tire question(noob question but just a quick answer needed) 07SilverX JK Wrangler Technical Forum 3 12-25-2007 03:35 PM
