CB Radio Turns Off When I Hit A Bump - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > CB Radio Turns Off When I Hit A Bump
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitThe Original 3/8" Ruffstuff Diff Cover!Building a Bumper?
Unread 07-07-2014, 02:10 PM   #1
nbmarti2
Hey all,
I recently installed my grandpa's old CB in my Jeep. I tested the PA function (it works), still haven't gotten any chatter from the AM setting (possibly from wrong tuning), and now the thing kicks off randomly. It did this when I first installed, then I took it apart and checked for a short but couldn't see any visually so I put it back together and reinstalled. After this it worked even through the bumps for a day or two but eventually went back to shutting off when I hit a bump in the road. I have to whack it to get it to turn back on but it inevitably turns off again at the next bump.
I need help understanding:
1-What could be causing this CB to malfunction and how can I fix it?
2- Any advice on how to tune it so that I can know for sure if I am receiving or not?
I will upload pics and a model # once I'm out of work.
Thanks!
nbmarti2 is offline   Reply With Quote
Unread 07-07-2014, 07:03 PM   #2
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
My guess is a wire broken inside the insulation where it enters the unit.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is online now   Reply With Quote
Unread 07-07-2014, 09:22 PM   #3
JonCorwin968
Check the resistance on the wires. If one or both is showing really high resistance or no connection thats your problem. Also give the wires a wiggle and the radio a wack when you do it. It would be best to test it when It's not working.
JonCorwin968 is offline   Reply With Quote
Unread 07-07-2014, 09:26 PM   #4
Old4X
1990 CJ7
A cold solder joint internally will do that. As mentioned, wiggle stuff when it quits, may have to take the cover off and wiggle internal parts till you find it.
Rust free YJ for sale. Need more room in barn.
Old4X is offline   Reply With Quote
