caulk cowl seal? - JeepForum.com
post #1 of 18 Old 02-27-2013, 04:46 PM Thread Starter
chuck172
caulk cowl seal?
Can I silicon caulk the cowl gasket seal while it is in place?
Just pry it away from the windshield and shoot silicon in there and let the flap sping back?
Mine is leaking pretty bad.
chuck172 is offline
post #2 of 18 Old 02-27-2013, 05:00 PM
Berniebikes
don't do it. The part is cheap enough worst part about changing is getting your windshield down. Go ahead and take the old one out, clean everything up real well and replace it. You'll be glad you did in the long run
Berniebikes is offline
post #3 of 18 Old 02-27-2013, 05:16 PM
jcmooreusmc
^Agreed. I think it's around 20-25 bucks for a new one. Relatively easy to change so long as the torx bolts on the rollbar comply.
jcmooreusmc is offline
post #4 of 18 Old 02-27-2013, 07:00 PM Thread Starter
chuck172
I did change it last summer. Leaking like a sieve now, and I can't figure out why. I never will flip down the windshield, why shouldn't I just caulk it?
chuck172 is offline
post #5 of 18 Old 02-27-2013, 07:12 PM
jcmooreusmc
The only need to flip down the windshild in this case is to replace the seal. However, you stated that it was already replaced. Not sure why it would be leaking. Have you checked the cowl itself? I don't know for sure, but I've heard that it can become blocked and cause some leaking. I personally wouldn't caulk mine b/c it would not be fixing the problem correctly. That's just my opinion though. I hope you are able to find the cause and a fix for it.
post #6 of 18 Old 02-27-2013, 07:56 PM Thread Starter
chuck172
If I can wait till the weather warms up and then i can remove the hardtop. Then I'll give a new seal a shot. But if I can caulk it in place right now what would that hurt?
chuck172 is offline
post #7 of 18 Old 02-27-2013, 08:28 PM
DirtKar
I pledge allegiance.
DirtKar's Avatar
Looks like you've made up your mind since you've posted the same thing 3 times. Of course you can try to caulk it in place. The problem is, the rubber will expand and contract to the point that the sealant won't stick properly and you will be forced to deal with the mess in addition to installing he new seal at some point. Give it a shot, just be prepared to deal with it later. Make sure your drain on the firewall is clear as well so that you aren't misdirecting your leak stopping efforts. Good luck.
Luck Favours The Prepared
YJOTM JULY 2014
DirtKar is offline
post #8 of 18 Old 02-27-2013, 08:49 PM
Old4X
1990 CJ7
Try some plumbers putty. It isn't permanent, will come off easy and will stop that area from leaking. You will probably find you are leaking from other areas as well: hinges, around the glass, cowl air duct, etc.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #9 of 18 Old 02-27-2013, 09:26 PM
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
You can find out if it's that gasket leaking or not by putting come clear packing tape over it as it sits. No commitment to silly crap that may not fix the problem. Tape is easy cleanup to take off whenever.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is online now
post #10 of 18 Old 02-28-2013, 04:24 AM Thread Starter
chuck172
I got a little frustrated there, calmer minds prevail. I'll just wait till spring and replace the seal again. No sense making a big mess and causing more work down the line.
chuck172 is offline
post #11 of 18 Old 02-28-2013, 07:58 AM
Rproject
1987 YJ Wrangler
Are you sure it's the cowl seal that's leaking and that the fresh air intake isn't blocked?
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #12 of 18 Old 02-28-2013, 08:18 AM
zeus87gn
1987 YJ Wrangler
Here's a different view - I replaced the lower windshield seal on my boys 92 when we did his dash
I put some of that black sticky caulking strip stuff on it, between the frame and the seal, and it seemed to help...at first
It started leaking a few months later and didn't stop until I cut that big upside-down outside lip off so the seal was flush with the outside of the body
No more leaks
I had many leaks with my own 87 - cut the lip off and it quit, but I still have a leak somewhere else in the firewall/cowl area
It leaks down the inside of the firewall instead of on me like it did before I cut the outer lip
I'm thinking probably from the body seam at the base of the windshield support of the cowl
My buddies 89 was leaking like there was no tomorrow whenever it got wet from anything
Cut the outer lip off and his leaks are minimial now....even with a hose
We're still working on it tho...
Handicapped license plates are not for mentally handicapped people -
"Man has not yet evolved an inch from the primordial slime that spawned him." Mark Blankfield, Jekyll & Hyde... Together again
zeus87gn is offline
post #13 of 18 Old 02-28-2013, 12:58 PM
StanF
Originally Posted by zeus87gn View Post
snip.. I cut that big upside-down outside lip off so the seal was flush with the outside of the body...snip
I recently replaced the seal on my 1995. It wasn't leaking (that I know of, but I never drive in the rain), but it was old and cracking.
The design of the seal is really idiotic, so cutting off the upper outside lip would make a lot of sense.
BTW, I'm having trouble with my new seal "squeezing" out front a bit when I rotate the windshield in position. I need to get 5 friends (10 hands) over to help hold it in position while I bolt the windshield down.
I also thought about using RTV to help hold it in position. Will likely never drop the windshield again...
StanF is offline
post #14 of 18 Old 02-28-2013, 02:29 PM
Rproject
1987 YJ Wrangler
I don't understand the theory of caulk or RTV to hold a cowl seal in place. They're mechanically secured to the body with several fasteners along their length.
1996 White ZJ
Rproject is offline
post #15 of 18 Old 02-28-2013, 03:35 PM
StanF
I think there are 4 or 5 screws holding a 5' long piece of rubber. The rubber bulges where the screws aren't...
StanF is offline
