the cat - JeepForum.com
post #1 of 16 Old 04-22-2010, 02:36 PM Thread Starter
jdtuck91
1993 XJ Cherokee
the cat
anybody know what would happen to a 91 4.0 if the cat was bypassed
jdtuck91 is offline
post #2 of 16 Old 04-22-2010, 02:39 PM
RebuildRookie
fail emissions (if your required) in your state?
and I believe you have a O2 sensor back there as well. You would probably get fault codes for that. Otherwise mechanically probably no adverse effects.
Also, may be illegal in your state to remove the CAT, not for sure though.
I'm a more proactive person.
You spray the ants before they get in your house.
You plant the crops before you starve.
And you keep the terrorists in check before you get your *** blowed off.
RebuildRookie is offline
post #3 of 16 Old 04-22-2010, 02:47 PM
NHfireLJ
NHfireLJ's Avatar
Looked under my 94 the otherday..(bought last Nov) No cat! Runs fine.
For the record, I did not remove it... But when I replace the exhaust I will of course reinstall one...For emissions sake
NHfireLJ is online now
post #4 of 16 Old 04-22-2010, 03:01 PM
QuantumYJ
5...4...3...2...1...
Where's Rusty?
I've been on the internet too much lately. Now, even I'm beginning to think that "breaks" are what you use to stop your Jeep.
QuantumYJ is offline
post #5 of 16 Old 04-22-2010, 03:39 PM
beachedjeepyj
Where's Rusty?
Haha i think he is on vacation.....
No more talk about removing the cat as it will result in the ban hammer.
http://www.jeepforum.com/forum/f180/cat-removal-302288/
Originally Posted by Jeep89JV View Post
Do I let others drive my rig? No -- Why, because if this ship sinks i'll be the captain and I go down with this ship.
beachedjeepyj is offline
post #6 of 16 Old 04-22-2010, 04:47 PM
QBCoach
What no cat??? On EARTH DAY...i'm telling Al Gore!
02 WJ Overland- Daily Driver...keeping it stock for now
94 YJ- work in progress
"If it ain't broke...just give it time!"
QBCoach is offline
post #7 of 16 Old 04-22-2010, 07:26 PM
ronfezz
i passed emissions here in ct. without a cat, yet failed for its not being there. got a new one on there now no loss in power from my 4
ronfezz is offline
post #8 of 16 Old 04-22-2010, 07:31 PM
dadstoys2
1987 YJ Wrangler
Hi flow cats are cheap and keep you legal. There is no major gain by removing it unless its bad anyway. But you will catch alot of crap by removing it from some due to polluting the enviroment for no reason. Its a jeep not a race car.
~Rich
87 Wrangler Ford 302
2"bodylift 5"suspension 35" bfg A/Ts
Np435 trans w/ np205
dadstoys2 is offline
post #9 of 16 Old 04-22-2010, 08:35 PM
provinT13
Nothing. You will fail emissions, but the o2 sensor is before the cat so you don't have to worry about messing that up.
It's illegal to remove the cat under federal law, not saying your removing yours though, there is nothing wrong with asking a hypothetical question.
2 Hands Working Do More Than 1000 Hands Praying
provinT13 is offline
post #10 of 16 Old 04-22-2010, 08:54 PM
4LarXedo4
Why would you want to bypass your cat in the first place? There's many closed threads on cat removal and bypassing it, but why... if Your motor is stock then what is the point? There will be no performance gain at all, it's a Jeep not a racecar. Also as the other member touched on the topic of o2 sensors and is correct, Once your vehicle is up to operating temp in closed loop it utilizes the o2 sensor to determine the correct air/fuel mixture (after the exhaust has gone through the cat) for your engine to run properly and efficiently. I could go on for awhile on this but i'll save ya'll the boredom.
4LarXedo4 is offline
post #11 of 16 Old 04-22-2010, 09:14 PM
MJMPC
On my 91 YJ the o2 sensor is BEFORE the cat and there is only one.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #12 of 16 Old 04-22-2010, 09:25 PM
4LarXedo4
On vehicles with only one sensor before the cat are still used to determine pre-catalyst efficiency, Most vehicles with this setup (not sure on Jeep) the o2 sensor sends a signal to briefly lean the mixture in order to help the 'chemical process' and keep the exhaust somewhat 'clean'. That being the case, yes you could bypass the cat with no ill effects from a non existing post cat sensor, but once again, there will be no performance gain.
post #13 of 16 Old 04-22-2010, 10:09 PM
dadstoys2
1987 YJ Wrangler
I have an 87 with a webber and no computer at and still run the cat. Its cheap enough to just replace with a hiflow if you want less restriction.
~Rich
post #14 of 16 Old 04-22-2010, 10:26 PM
BlackRhino
BlackRhino's Avatar
There is NO benefit to removing the cat. It does not restrict flow in any measurable way. Just leave it in and stay legal.
Black '91 YJ, pretty much stock for now. Finished engine rebuild. Runs beautifully.
BlackRhino is offline
post #15 of 16 Old 04-22-2010, 10:26 PM
K4KAS
It is a $5000 fine to remove a known working cat. Not to mention a federal law.
That being said, mine didnt have one when I got it. I got tired of the raw fume smell. Then I looked under a realized there was no cat. I hat one put in by a cheapo muffler shop. No more fumes! It was really bad when the top was down or back window out. The Jeep seems to run smoother/better with it actually. It did change the tone of my exhaust note a bit. But the flowmaster never complained and it still sounds good.
With all this being said, I didnt get a check for $5000 when I put it back on!
K4KAS is offline
