Caster angle question - JeepForum.com
post #1 of 31 Old 11-23-2015, 08:42 PM Thread Starter
manvstaco
Hello all! I have a question regarding my caster angle and drive-ability. PO installed a 4 inch rough country lift without modifying the caster angle on either axle, it does have the tcase drop but no leafspring/caster shims, steering wheel is a crooked as well (to the left). My friend is telling me to get 3 degrees shims, and I am seeing some of the 4 inch lifts actually come with 4 degree shims. Everything I am reading says to avoid the aluminum ones as the wear out and flatten creating problems. My steering is a bit crazy and am told this would help as it is currently my DD. What do you guys think?
Image below is my caster angle from my alignment a couple weeks ago.
manvstaco is offline
post #2 of 31 Old 11-23-2015, 08:59 PM
jbolty
jbolty's Avatar
Do you have extra long shackles.
Are your track bars still on?
jbolty is offline
post #3 of 31 Old 11-23-2015, 11:27 PM Thread Starter
manvstaco
PO removed rear track bar and sway bar. I removed the front track bar and reinstalled the sway bar with quick disconnects. I feel like it drives better with track bars removed, and sway bar installed down the freeway. Here are pictures of the front shackles. what do you think? They are beefy compared to some of the goofy stuff I have seen people make. Would changing these out be a better route than caster shims?
post #4 of 31 Old 11-24-2015, 05:02 AM
ACs95YJ
It looks like you could benefit from a drop pitman arm. You're probably getting a lot of bump steer from the steering angle.
Sent from AutoGuide.com Free App
95 YJ 2.5L AX-5, 4" Zone Springs, 1" BL, 5/8" Booms, Hercules 33-12.50's, Dodge Ram brake lines
ACs95YJ is offline
post #5 of 31 Old 11-24-2015, 05:04 AM
ACs95YJ
Also, on my rear axle I actually had to run 8 degree shims. I think every setup, lift, and jeep can be just a little different.
ACs95YJ is offline
post #6 of 31 Old 11-24-2015, 08:26 AM
Randonexplosion
Deplorable
Randonexplosion's Avatar
Those shackles appear to be 6" bolt to bolt, so they are a 1" lift shackle. That will rotate your axle forward and negatively affect your caster. I felt a big (bad) difference just installing 5/8" lift shackles.
Randonexplosion is offline
post #7 of 31 Old 11-24-2015, 10:52 AM Thread Starter
manvstaco
So what should I do? Caster shims or new shackles?
Also the pitman drop arm, would this work ?
http://www.quadratec.com/products/16197_150.htm
post #8 of 31 Old 11-24-2015, 11:02 AM
Randonexplosion
Deplorable
Can you stand to lose an inch of lift? I tried doing some shims up front but I didn't notice any difference. Can't remember which ones I used.
post #9 of 31 Old 11-24-2015, 11:24 AM
Reno72
Drop pitman arm won't fix your caster, though it may help bump steer. Going to a 1/2 inch shackle lift may do the trick. Never tried shims up front, but never heard any positive results from it either. They also have adjustable ball joints, but the simple fix would seem to take the shackle lift lower.
92 Rene, 4.5 RE lift, Currie ARB D44, super 8.8 ARB
YJOTM. 12/15
Reno72 is offline
post #10 of 31 Old 11-24-2015, 11:28 AM Thread Starter
manvstaco
I've got tons of bump steer, would that pitman arm drop link I provided above work for me? Anything else I should buy along with it?
post #11 of 31 Old 11-25-2015, 07:04 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
A stable ride is not determined by the caster angle directly. It is determined by a proper 'Lead Point to the Contact Point' distance (see photo). The OEM caster angle was/is specified for stock size tires. If you increase the diameter of the tire, the Lead to Contact distance increases.
It's fine to have a less than spec caster angle for larger tires. I also question the target number on that readout sheet. When mine was done at Firestone, the target was 6-6.5°, not way up to 9°. Having 5° with 33's would end about the same Lead to Contact distance as 6-6.5° with stock tires. I'll leave it to you to do the trigonometry to see what your Lead to Contact is now. I doubt at all that your issues are due to caster. So, go with what was said above, fix your steering linkage!
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #12 of 31 Old 11-25-2015, 07:20 AM
JeeperDon
JeeperDon's Avatar
[Digression: What most new people to Jeeps don't realize is that the whole OEM Jeep was designed as a system, a lot of things with the right specs working together to make a nice stable Jeep out of the dealer lot. Whenever you alter one thing under the Jeep, it cascades around to mess up a lot of other things. In this case, the lift was added with no consideration for the steering. Only after you address all the downstream issues from making one mod will the overall stability be there again.]
Web Admin for
post #13 of 31 Old 11-25-2015, 11:13 PM Thread Starter
manvstaco
Ok so I bought the drop pitman arm and the puller from quadratec today. As far as my caster angle goes, it seems you guys are leaning towards new shackles. Does anyone have any recommendations? Should I just wait till I have the new pitman arm installed or would changing my caster angle with new shackles be worth while?
Thanks for all the help
post #14 of 31 Old 11-26-2015, 12:35 PM
mark1305
mark1305's Avatar
I'd say if you are happy with the lift you currently have out of your spring/shackle combo and your u-bolts aren't rusted to the point that changing shims would be a PITA, I'd use the info posted above about calculating caster/lead/trail. Then order some shims to get the caster correct for your size tires.
If you have enough tire clearance to go shorter shackles, that may be easier, but you may still have a need to swap shims even after going to shorter shackles. It's one of those cases where "you make your choice and puts your money down and takes your chances." (That's the old style of an old quote).
I have a lift kit to install sometime this winter and luckily have 3 sets of shims to play with and can always order more if none of them give me the right pinion angle or the right caster up front.
mark1305 is offline
post #15 of 31 Old 11-26-2015, 07:52 PM
JeeperDon
JeeperDon's Avatar
Math is your friend. Reducing shackle length on a YJ by 3/4" (0.78" actually) increases the caster by 1°.
Web Admin for
