Carter BBD Issues - JeepForum.com
post #1 of 7 Old 03-08-2010, 11:17 PM Thread Starter
Hawk37
Carter BBD Issues
So, I have a 89 4.2L. I just finished the nutter bypass, and rebuilding the carb. Once I had everything back together I tried turning the key, and it just kept turning over and over.
When I checked everything out, I didn't have any fuel in the carb. So, I decided to pour some gas in the carb. It fired right up and then died. I put in a new fuel pump. Now I have gas in the bowl, but the engine still isn't starting.
I'm not much of a carb guy, but I followed the instructions of the rebuild kit to the T. Any Ideas?
Hawk37 is offline
post #2 of 7 Old 03-11-2010, 11:13 AM
RobsCrawlin7
no balls
RobsCrawlin7's Avatar
i am having the same exact problem except mine is firing and fuel keep overflowing in the carb. i cant find a good diagram
'01 TJ 4.7/NV3550, 2" lift, 35's, locked.
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
SSG David Mejias, SSG Eric Vick, SGT William Bowling, SGT Robert McDowell
1 April 2007
Rest In Peace Brothers
RobsCrawlin7 is offline
post #3 of 7 Old 03-11-2010, 06:10 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Does this help you two; Download it for future reference.
http://home.comcast.net/~laybackman/bbd.pdf
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #4 of 7 Old 03-11-2010, 07:23 PM Thread Starter
Hawk37
Yeah, That's the exact sheet that came with my rebuild kit.
I figured out that I have a huge vacuum leak around the throttle shaft. I noticed that the shaft was leaking gas when I poured it in to start the engine, but wasn't while it was running. It really messes up the spray if there isn't enough vacuum to pull the fuel in.
I double checked my vacuum leak theory by running the engine and spraying carb cleaner around the carb. If any gets into the engine its an instant octane boost (the engine revs up).
Either I get the thing reshafted by a machine shop or look for a new carb.
Hawk37 is offline
post #5 of 7 Old 03-11-2010, 08:13 PM
RobsCrawlin7
no balls
my carb is totally screwed, i ordered a new one. thanks for the diagram though
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
1 April 2007
post #6 of 7 Old 03-11-2010, 09:24 PM
hh65pilot
This is pretty simple but did you put the fuel line back correctly? Make sure the filter is higher than the fuel inlet on the carb. Just a guess. If it's higher than it sounds like a ignition/distributor problem to me. The wires running to the back of my distributor were loose and I had the symptoms you currently have. I tweaked the wires and ran them on top of the vacuum advance and it started right up. Now I'm waiting for my next problem to show up.
hh65pilot is offline
post #7 of 7 Old 03-11-2010, 09:39 PM
Dado99TJ
Junior Member
Dado99TJ's Avatar
If you're interested in doing a swap, take the POS Carter off and throw it away and swap in a Motorcraft 2100/2150 carb. If you look around, you can find quite a few write ups on here with detailed instructions. Its simple, can be cheap, and will give you more power. Just a thought.
Nightcrew member #331
Blue Jeep Club member #332
Dado99TJ is offline
Carter BBD Missouribound YJ Wrangler Technical Forum 6 06-10-2009 09:52 PM
I have had it with the carter!!!!! fireshadow YJ Wrangler Technical Forum 10 03-19-2009 09:39 PM
Need some help with the Carter Chews YJ Wrangler Technical Forum 4 04-07-2007 01:27 PM
Carter, why must you do this to me? 88YJWranglerBoy YJ Wrangler Technical Forum 4 02-11-2005 03:59 PM
Is it the carter??? JeepinSC87 YJ Wrangler Technical Forum 6 07-06-2003 10:04 AM
