carter bbd check ball - JeepForum.com
post #1 of 3 Old 11-05-2007, 07:53 AM Thread Starter
bfzmlp7
Does anyone out the know the size of the check ball for a carter bbd.
Took mine apart to fix venturi tubes and lost mine or it wasnt there to begin with.
I had a broken venturi tube and thought I had it beat till I got the kit from Injector Tech and went to put it back together and noticed no Check Ball.
bfzmlp7 is offline
post #2 of 3 Old 11-05-2007, 08:22 AM
MUDBUG J
It should be included in a rebuild kit.
MUDBUG J is offline
post #3 of 3 Old 08-14-2009, 02:34 PM
jmenegazzo
I need that measure please!!! my housekeeper stumbled with me while taking apart my BBD and didnt noticed I was missing the check ball until assembly. please help!!!! (didnīt want to hijack thread, but this way I donīt make a new one about the same)
"If It Scares You, Then Do It"
"Jeep Harder"
--Your YJ is like sex, when itīs good itīs terrific and when itīs bad itīs still pretty good.--
jmenegazzo is offline
A check for ball joints? Voyame JK Wrangler Technical Forum 9 11-22-2009 03:07 PM
Carter BBD Check Ball CajunHiker YJ Wrangler Technical Forum 2 08-02-2009 12:05 PM
trans line check ball 88wagon TJ Wrangler Technical Forum 1 02-25-2008 09:28 PM
Carter check ball? 1Chavez YJ Wrangler Technical Forum 7 02-27-2007 09:39 AM
Carter BBD problems? Check out this site! muddymark YJ Wrangler Technical Forum 0 11-14-2001 09:00 PM
