Carrier Gears on a D35 - JeepForum.com
post #1 of 4 Old 07-15-2006, 10:23 PM Thread Starter
mrbigglesworth
mrbigglesworth's Avatar
Hey my friend has a 94 Wrangler Renegade 6cyl 5spd and his spider gears broke. He has a D35 rear so i gave hime some old gears i had from my 1990 6cyl spd. He claims the gears are different and dont fit. Is this possible?? Shouldn't the gears be the same??
?[]|||||||[] Black 1990 YJ 4.2L 6cyl 5spd []|||||||[]
BLACK JEEP CLUB #1000
Mods:
3.5" Rough Country Lift Kit
2 inch shackle lift
JKS Telescoping front track bar
33"x13.5" Super Swampers with 15" x10" AR Wheels
Front and Rear Auto Lockers
SYE and CV shaft in rear
Motorcraft Carb Conversion
Imperial Electric Cooling Fan
Grill Guard Front Bumper
Hella Bumper Lights
Rear Towing Crossmember and Hitch
Diamond Plate Running Boards
CB Radio
mrbigglesworth is offline
post #2 of 4 Old 07-16-2006, 12:05 AM
hdfxrs91
1987 YJ Wrangler
The '94 has C-clip axles and you probably have the non-C-clip axles. IIRC the C-clips started around '91 or so. I could be wrong, though.
hdfxrs91 is offline
post #3 of 4 Old 07-16-2006, 01:44 AM Thread Starter
mrbigglesworth
we both have c clip style axles. Is it possible there is a limited slip diff offered on the renegade?
Mods:
2 inch shackle lift
Hella Bumper Lights
CB Radio
post #4 of 4 Old 07-16-2006, 06:12 AM
fratis
fratis's Avatar
the limited slip will be very obvious. it is possible. bottom line if they dont fit they dont fit. try again with another set.
fratis is offline
new gears, mean new carrier? jcapodicapi TJ Wrangler Technical Forum 12 07-22-2009 09:46 PM
3.73 gears in a 3.07 carrier? ET48 TJ Wrangler Technical Forum 1 10-03-2008 11:44 AM
New gears. new carrier? canuckyj YJ Wrangler Technical Forum 3 11-28-2005 05:46 PM
Carrier And Gears skp94yj YJ Wrangler Technical Forum 6 03-10-2005 09:09 PM
