Carrier And Gears - JeepForum.com
post #1 of 7 Old 03-10-2005, 07:12 PM Thread Starter
skp94yj
Carrier And Gears
I HAVE A 94YJ WITH D30 FRONT AND D35 REAR WITH 3:07 GEARS AND I WANT TO PUT 4:10 GEARS IN. I KNOW I NEED NEW CARRIERS TO RUN 4:10 GEARS AND I FOUND A SET OF FRONT AND BACK FOR A GOOD DEAL BUT THEY ARE OUT OF A 97 OR NEWWER TJ AND ALL MY CATALOGS GIVE A DIFFERNT NUMBER FOR THE D30 FRONT IN A TJ THAN THE D30 FRONT IN MY YJ. WHAT IS THE DIFFERENCE AND IS THERE A WAY TO MAKE THEM WORK? THE BACK SEEMS TO BE THE SAME BUT IF I"M WRONG LET ME KNOW. ANY INFO WILL BE GREAT!!!!!!!!!!!!!
skp94yj is offline
post #2 of 7 Old 03-10-2005, 07:20 PM
chopperkid2000
Naw i think the rear is different , and the front should be the same Not real sure someone here should know.. If you have any trouble let me know i just pulled a d 35 outta the rear of mine which has stock 4.10 gears new drain plug cover and brand new drums shoes etc. I will sale for 125 $.. I just put in a ford 8.8 and locker. The d 35 works great it came out of my 95 YJ which has 87000 miles.. Good luck
chopperkid2000 is offline
post #3 of 7 Old 03-10-2005, 07:42 PM Thread Starter
skp94yj
Thanks For The Info And The Offer For The Rear. I Really Want To Do The Same Thing With A 8.8 But Im Pressed For Time And My D35 Is Vibrating Bad And Im Going On A Trip With It Next Weekend. I Was Just Gonna Put The Gears That My Buddy Has Because They Are Cheap And Avalible. Thanks For Replying Though!
skp94yj is offline
post #4 of 7 Old 03-10-2005, 07:45 PM
ErikJordan
Pimp Hand
ErikJordan's Avatar
the dana 30 on a yj is completely different than a tj.
the yj is "reverse cut" the tj is not. the yj is a stronger dana 30.
___________________________________________
What is all of this talk of Savvily designed products?
ErikJordan is offline
post #5 of 7 Old 03-10-2005, 07:52 PM
tobias94yj
Hillbilly Member
tobias94yj's Avatar
you will also hear people refer to yj and xj d30's as HP D30's for high pinion. the rears are the same with the exception of the hardware to mount the suspension. your d30 also has cast rotors instead of the cheaper composite rotors found on tj's
To view the NEW
click here!!!
tobias94yj is offline
post #6 of 7 Old 03-10-2005, 07:54 PM
tobias94yj
Hillbilly Member
tobias94yj's Avatar
what do you mean by your d35 is vibrating? are you lifted and how much? do you have a t-case drop if you are lifted? I have never heard of a rearend vibrating. are you guys going to do the gear swap?
To view the NEW
click here!!!
post #7 of 7 Old 03-10-2005, 08:09 PM Thread Starter
skp94yj
I Have A 2.5 Bds Lift With The Drop T Case And 31's. I Already Replased The U-joints And T Case Mount. I Pulled The Cover Off And The Spidder Gears Are Worn Pretty Bad And The Move Back And Forth (if You Know What I Mean ,not The Normal Moveing) Any Sugegtions Thanks
skp94yj is offline
new gears, mean new carrier? jcapodicapi TJ Wrangler Technical Forum 12 07-22-2009 08:46 PM
3.73 gears in a 3.07 carrier? ET48 TJ Wrangler Technical Forum 1 10-03-2008 10:44 AM
Carrier Gears on a D35 mrbigglesworth YJ Wrangler Technical Forum 3 07-16-2006 05:12 AM
New gears. new carrier? canuckyj YJ Wrangler Technical Forum 3 11-28-2005 04:46 PM
