Carburetor Question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Carburetor Question
Light up the holidays with LED lights from JeepHutIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffstuff Axle Simple Swap Kit!
Unread 10-31-2013, 01:34 PM   #1
PhillipO1990
Carburetor Question
I have a two barrel carb. I believe it is the Carter BBD based on comparison to pictures I have seen.
The Barrel closest to the driver side does not look like it is getting any gas. Before I take this thing apart, is there a fix that does not require that?
Also will it cause damage to the carb/engine if it is driven before the problem is fixed?
PhillipO1990 is offline   Reply With Quote Quick reply to this message
Unread 10-31-2013, 02:27 PM   #2
atopi3
You can try clearing the jets. To do this start the motor remove the air cleaner put some good leather gloves on and put you hand right on top of the carb and choke it out restart and see if that helped. If you can I would replace the BBD with a 2100 motorcraft 108 venturas #47 jet for under 1000 ft.This will wake your motor up I assume you got the 258 6 cyd. I bought mine for 285.00 Ebay.Ridgerun31 is his name best money I spent on my rig
atopi3 is offline   Reply With Quote Quick reply to this message
Unread 10-31-2013, 02:42 PM   #3
PhillipO1990
Yes that is what I have. Thanks for the tip. I will try that out when I get home.
Unread 10-31-2013, 03:04 PM   #4
Old4X
1990 CJ7
If you haven't put in a Zip kit in the last several yeqrs, it is time.
Tear it down. Tank soak the parts. Reassemble as per the specifications. Enjoy a better running engine and better gas mileage.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline   Reply With Quote Quick reply to this message
Unread 10-31-2013, 03:24 PM   #5
AmmitOsiris
Originally Posted by Old4X
If you haven't put in a Zip kit in the last several yeqrs, it is time. Tear it down. Tank soak the parts. Reassemble as per the specifications. Enjoy a better running engine and better gas mileage.
What's a zip kit?
Sent from Peggy's office
AmmitOsiris is offline   Reply With Quote Quick reply to this message
Unread 10-31-2013, 03:28 PM   #6
86cj74.2L
86cj74.2L's Avatar
Originally Posted by AmmitOsiris
What's a zip kit? Sent from Peggy's office
A rebuild kit.
If you have passages clogged with dirt its time to take it apart and clean it. Soak everything not plastic in a can of carb dip overnight, then blow out all the holes and passages with carb cleaner and put back together.
86cj74.2L is online now   Reply With Quote Quick reply to this message
Unread 11-05-2013, 03:47 PM   #7
PhillipO1990
Can anybody recommend a good kit and what major stores carry it?
Unread 11-05-2013, 04:15 PM   #8
superj
1987 YJ Wrangler
You can get one from your local auto parts place or any online carb place. They will almost undoubtably be from the same manufacturer
Slow ride, take it easy
superj is offline   Reply With Quote Quick reply to this message
Unread 11-05-2013, 04:41 PM   #9
Chrisnvegas
Chrisnvegas's Avatar
Here is a brand spankin new carb for $190 bucks. I like the carter. But, after 25 years they tend to wear out. I keep my Jeep emissions compliant. You never know what kind of crap the gubment is going to come up with.
http://www.ebay.com/itm/160-NEW-CARB...cb0a09&vxp=mtr
What happens in my Jeep, stays in my Jeep
Chrisnvegas is offline   Reply With Quote Quick reply to this message
Unread 11-05-2013, 07:57 PM   #10
86cj74.2L
86cj74.2L's Avatar
Originally Posted by Chrisnvegas
Here is a brand spankin new carb for $190 bucks. I like the carter. But, after 25 years they tend to wear out. I keep my Jeep emissions compliant. You never know what kind of crap the gubment is going to come up with. http://www.ebay.com/itm/160-NEW-CARB...cb0a09&vxp=mtr
Just so you know that is a china clone carter. Unless you find a NOS carb you won't find a new carter. Some have them on the CJ Fourm. I use the napa kit for rebuilding.
You can tell a clone by the white fuel bowl vent instead of yellow.
Unread 11-05-2013, 08:11 PM   #11
Chrisnvegas
Didn't know that. More stolen intellectual property from the communists.
Unread 11-05-2013, 08:29 PM   #12
86cj74.2L
86cj74.2L's Avatar
I think its more to do with the patent expired. Look at all the cheep CDI multi spark ignitions now.
The only thing that wares out on them a the throttle shaft bushings. For less than 25 dollars you can buy the tool and sintered bronze oil impregnated bushings and have a brand new carb.
Also drilling out the emulsion tubes to a larger hole helps atomize the fuel better and the larger hole helps prevent clogging. Which they do on occasion. I think I drilled them to .037.
