Carburetor Base Plate - JeepForum.com
post #1 of 7 Old 06-29-2011, 04:12 PM Thread Starter
Twrecks
1987 YJ Wrangler
Managed to break my carburetor base plate (the plastic / rubber one between intake and carb). Where can I find a replacement? I've called around and noone has them.
edit: I guess this also called an insulator plate.
Twrecks is offline
post #2 of 7 Old 06-29-2011, 08:47 PM
superj
can you get one off the performance wall at hte local auto parts place? take your old one in and hold it up to the ones they have? or check in the rebuild kit for your stock carb? my holley rebuild kit came with the insulator in it
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #3 of 7 Old 06-29-2011, 10:37 PM Thread Starter
Twrecks
1987 YJ Wrangler
unfortunately the part is discontinued. Ive potentially found 1 in New York, but I'm not sure. Its a real big PITA for such a small part
Twrecks is offline
post #4 of 7 Old 06-30-2011, 05:01 AM
DocWills
Carb rebuild kit or buy any adapter plate, it ought to have a fat gasket as well. Either way, $20.
DocWills is offline
post #5 of 7 Old 06-30-2011, 08:04 AM Thread Starter
Twrecks
1987 YJ Wrangler
The rebuild kit comes with the paper gasket, but I need the insulator plate which is made of plastic material and about 3/4" thick. Even the junkyards in my area don't have any!
Twrecks is offline
post #6 of 7 Old 06-30-2011, 03:44 PM
04WJny
1987 YJ Wrangler
have you thought of making one. from what i remember its a spacer with two large holes for the throat of the carb and 4 holes that fit over the studs. shouldnt be too hard to make with a drill bit and a hole saw.
2004 WJ I6 4.0L DD
1987 YJ I6 4.2L Weber 34 DGEC carb, 4in RC, Custom 1 inch BL,Custom Steering box skid, homemade rear bumper with tire carrier, 33x12.5x15 KM2's on
Cragar Soft 8's, and a few other things
In the process of putting in an 8.8, d30, 4.10's, SOA, and a homemade belly up skid
04WJny is offline
post #7 of 7 Old 07-01-2011, 06:14 PM
NonRubicon
What carb do you have? If it's the Carter you can get the carb base gasket from Autozone.
NonRubicon is offline
2011 Blue Ox Base PLate dbritsch JK Wrangler Technical Forum 6 10-07-2010 05:07 PM
Need Help w/ Winch Bumper,Base Plate, & Braking System devarona JK Wrangler Technical Forum 1 02-12-2010 04:25 PM
Base Plate Question Oceanedge TJ Wrangler Technical Forum 4 12-13-2009 07:37 AM
base plate vs aftermarket bumper TJDaveX TJ Wrangler Technical Forum 0 12-19-2007 10:26 AM
