Carburator question - JeepForum.com
post #1 of 29 Old 08-14-2012, 08:44 PM Thread Starter
mudsling
Carburator question
You guys in the know, just got a 87 yj 6 cyl 4.2l. It needs a new carb, what do you guys recommend for a replacement? It does not have an electronic feedback. Thanks in advance!
mudsling is offline
post #2 of 29 Old 08-14-2012, 09:36 PM
Jeepsr4me
motorcraft 2100 series
Jeepsr4me is offline
post #3 of 29 Old 08-14-2012, 10:53 PM
plym49
Respectfully disagree. Replace it with what it came with.
Also, why do you think it needs replacing? The majority of 'bad' carburetors respond well to a thorough rebuild, including dipping is a good-quality carb cleaner (not spray cans, the stuff that comes in 1 or 5 gallon cans - NAPA sells it).
plym49 is offline
post #4 of 29 Old 08-14-2012, 11:40 PM Thread Starter
mudsling
The first thing I did was to take it to a carburetor place to be rebuilt. The same problem persisted, the float gets stuck and the truck shuts down. I took it to yet another mechanic and he couldn't fix it neither. I actually found a tread about a carb install that used kit WK551 34 DGEC from Quadratec. The carb that I have is a Weber and it looks identical to the 34 DGEC. What do you guys think?
mudsling is offline
post #5 of 29 Old 08-15-2012, 01:01 AM
troy6187
If the float is getting stuck, then something is bent or worn. Or the carb needs cleaned very well. And no disrespect to the guy that said to use what it came with, but the stock carter bbd is a piece of junk. If you are really set on a new carb, then the motor raft 2100 or another webber are your best choices
troy6187 is offline
post #6 of 29 Old 08-15-2012, 04:06 AM
mudsweatNgearz
1987 YJ Wrangler
Motorcraft 2150 hands down!
I wondered why the baseball kept getting bigger and bigger....then it hit me!
mudsweatNgearz is offline
post #7 of 29 Old 08-15-2012, 06:47 AM
Old4X
1990 CJ7
Properly set up and maintained, the Carter BBD gives very good service.
None of the replacement carbs are engineered for the YJ. None have a fresh air ducting system or a heated air intake system for cold weather starts.
It is pure dumb luck if a replacement carb is properly jetted or has the proper power valve for the 4.2 engine.
Can one of these carbs be properly set up and tuned for the YJ? Sure, but it takes extensive carburetor experience to do it, and if the owner was this familiar with carburetor operation, their original carb would be working without issues.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #8 of 29 Old 08-15-2012, 08:21 AM
Jeepsr4me
Just do a search, On the crappyist carb ever put on a Jeep engine. That Carter BBD will be it. The one I said can be bought set up to drop straight on the 4.2 and run perfect. Guy rebuilds them and sets all the jets and other crap. I have owned only 4 carbed jeeps and would take a hammer to that carter cause I hated it.
post #9 of 29 Old 08-15-2012, 08:27 AM
Old4X
1990 CJ7
My BBD easily passed the state sniffer test, I have yet to see positive results on the other carbs. A little known secret on carb tuning is you can cover up many problems by running overly rich.
My BBD setup has a quarter of a million miles on it and is still a reliable daily driver. Would like to see results after several decades on these aftermarket carbs.
If the BBD was that bad, AMC, Jeep, and Mopar would not have put them on several million of their new vehicles.
There are people who can't properly operate a hammer, doesn't mean the hammer isn't a good tool in the right hands.
Old4X is offline
post #10 of 29 Old 08-15-2012, 08:32 AM
Jeff88
Does the same logic apply to the Peugeot transmission? The factories have certainly been known to make errors!
There are countless threads complaining about the Carter carb. At the very least this suggests that the carb had some issues, especially as it ages.
Maybe you just got a good one?
For myself, I bought the Motorcraft 2150 from the guy on ebay, performs absolutely flawlessly.
Jeff88 is offline
post #11 of 29 Old 08-15-2012, 08:46 AM
Jeepsr4me
These are not aftermarket carbs. They are carbs made by FORD. I use to go to the Junk yard and pull a motorcraft off a 60's or 70's truck or car, clean the inside of it out and put back together and run it as is. May have to change a jet or 2 but that is bone simple compared to that carter. They would run upside down, matter of fact I rolled a car and it wanted to keep running with me on the lid.
You may just be the lucky one with the carter you have. But countless others have the opposite experience.
Jeep has put some terrible parts in a jeep, all in a effort to save cost or just bad advice.
I HATE that carter and the BA10 trans. Well I should say I love them. Cause I have bought so many jeeps with one or both of those things bad. replaced with something better and made some coin
post #12 of 29 Old 08-15-2012, 09:00 AM
Old4X
1990 CJ7
If it isn't certified for the engine installation, it is, by definition, an aftermarket part. (Holley, weber, SU, et al, all made OEM carbs for one model or other vehicle).
Having owned more than a few of those motorcraft air/fuel mixers, I can attest that they are not without their own problems. Blown power valves, poorly designed and leaky accelerator pumps and auto chokes that won't stay in calibration from one season to the next.
That the motorcraft seems to work "out of the box" on a 4.2 only says it is running too rich. Do not remember owners of high gas mileage YJs or CJs running the motorcraft.
Nearly every used Jeep I have run up on with one of these wonder carbs is all but belching black smoke out the back, all the time while the owner brags about how well it runs and his 14 MPG.
Old4X is offline
post #13 of 29 Old 08-15-2012, 09:33 AM Thread Starter
mudsling
I found that the carb in it, is a weber. I call quadratec and tey have DGEC 32/36 for $336 it comes with a steper motor. Can you guys tell me what is the steper motor and do i need to install it. Sorry for the dumb questions, I can single handed rebuilt a YJ but I don't know anything about carbs.
mudsling is offline
post #14 of 29 Old 08-15-2012, 09:34 AM
Old4X
1990 CJ7
The stepper motor is for the computer control system. Not what you want if you aren't running the emissions computer.
Old4X is offline
post #15 of 29 Old 08-15-2012, 09:45 AM
zeus87gn
1987 YJ Wrangler
I went through 3 BBD's on my Jeep before I changed over to the Holley - the throttle shaft kept wallowing out the base of the carb and leaking vacuum - you must have got a 'wendesday' carb - have run into the same problem with webers too - my Holley setup did pass the Texas sniff test but it took a correct replacement cat to do it
Don't be fooled - Carter was lucky enough to get the contract because the other car makers were changing over to FI - they gave a cost break to AMC to get the business
QFT
Handicapped license plates are not for mentally handicapped people -
"Man has not yet evolved an inch from the primordial slime that spawned him." Mark Blankfield, Jekyll & Hyde... Together again
zeus87gn is offline
Carburator christopharmy1 YJ Wrangler Technical Forum 2 05-06-2012 10:04 PM
carburator question metalroses YJ Wrangler Technical Forum 0 06-15-2009 05:25 PM
carburator question byrdi YJ Wrangler Technical Forum 7 06-10-2008 06:41 PM
Need carburator HELP! RedWrangler89 YJ Wrangler Technical Forum 1 02-03-2007 07:38 PM
carburator kaleido YJ Wrangler Technical Forum 2 03-16-2002 03:28 PM
