carb problem - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > carb problem
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitRockridge 4WD IS Taking Zone Offroad Suspension Lift Kits End of Summer Sale, 20% OFF!
Unread 07-27-2014, 07:24 PM   #1
jammer89
carb problem
I was in the process of taking apart my carburetor in my 1989 jeep wrangler 4.0 to clean out the jets, and while trying to removed the hex screw that holds the electronic choke cable to the pin in the carb, the head of the bolt snapped off with the remainder of the bolt in the carburetor pin. Does anyone know where I can find one, order one, buy one, all the junk yards are cleaned out in the area and I cannot find one online. I really don't want to install a manual choke or purchase a new carburetor just for the pin!!!
Please advise
jammer89 is offline   Reply With Quote
Unread 07-27-2014, 08:16 PM   #2
Old4X
1990 CJ7
Put up a pic. If I don't have one, someone else probably does. I am not real sure which part you are referring to.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline   Reply With Quote
Unread 07-27-2014, 08:20 PM   #3
88_olympic
4.0 carbed?
88_olympic is offline   Reply With Quote
Unread 07-27-2014, 08:21 PM   #4
Old4X
1990 CJ7
Originally Posted by 88_olympic View Post
4.0 carbed?
It can be done. The 4.2 intake will fit th 4.0 head
Unread 07-27-2014, 08:24 PM   #5
88_olympic
If its a carter bbd there are exploded diagrams all over google image. Find the part number or a pic. I cant lend much help if its not a carter
Unread 07-28-2014, 06:40 AM   #6
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
I also am not real sure what pin you mean, but it almost sounds the the choke rod. Basically any broken off bolt can be carefully drilled out and rethreaded. When I drill them out, I get a bit slightly smaller than the bolt and drill it slightly off center so I end up with a crescent moon shape left, normally barely touching one small area of thread. This crescent shape can be backed out with an easy out or small screwdriver. Normally I don't even have to redo the threads.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote
Unread 07-28-2014, 04:05 PM   #7
rbthompsonv
Post a pic.. ive got lots of spare parts or could reference a lowes number for you...
rbthompsonv is offline   Reply With Quote
Unread 07-28-2014, 04:22 PM   #8
88_olympic
Kind of funny how all these people are ready to help and the OP is probably on hold with the stealership haha
Unread 07-28-2014, 07:37 PM   #9
Old4X
1990 CJ7
OK, the only hex screw I see on the whole carb is in the end of the choke plate shaft, holding a rod bracket on. I had to look at my installed carb as neither of my backup carbs has one in it at this time.
Just drill out the broken screw, tap to clean the threads, and install another screw.
eta: there is no need to remove that screw to access the jets, un hook the choke rods and just remove the top cover next time.
Unread 07-28-2014, 08:00 PM   #10
jammer89
Yes, it is the choke rod. I've tried to drill it out but had no luck. thought it would be just easier to get a new or used one somewhere but finding that difficult. Any help would be great.
thanks.
Unread 07-28-2014, 08:01 PM   #11
jammer89
yes it is the 4.2 carb.
Unread 07-28-2014, 08:09 PM   #12
rbthompsonv
WE NEED PICTURES!
I have LOTS of spare carter parts.. and am HAPPY to help... but need pics.
Unread 07-28-2014, 08:19 PM   #13
Old4X
1990 CJ7
It should be the choke rod that the butterfly plate is attached to. In this pic it has a slotted screw with a shake proof washer holding the rod plate onto the shaft. He needs the shaft and screw from what little he is telling us.
eta: the pivot axle that the choke plate itself is on.
Unread 07-28-2014, 08:30 PM   #14
Old4X
1990 CJ7
And from what I can tell, that is not a service part. A junk carb or a carburetor overhaul shop is your best bet. I do not have a spare top assembly, and this is how you will find one. Sorry.
