carb chevy 350 swap - JeepForum.com
post #1 of 4 Old 04-27-2010, 06:39 PM Thread Starter
muddigger0829
carb chevy 350 swap
I have a question about putting a carb 350 in the fuel injected yj.
would i need to replace the intank fuel pump or should it stay. how have you guys done the fuel system in this swap? any info will be helpfull. thanks
muddigger0829 is offline
post #2 of 4 Old 04-27-2010, 06:45 PM
notmyj
The pump will need to be eliminated. Carbs like 7psi, injection likes 40psi.
Personally, I think swapping in a carb is going 20yrs in the wrong direction. A TBI 350 is super easy to put in. On the trail, injection wins. Get off camber or up a steep incline and you will see the problems with carbs first hand. Injection will run standing almost verticle, a carb will spit and sputter.
Anyway, the carbed 350 should have a mechanical fuel pump on it, so all you will need is to get the supply line to the bottom of the tank. Not sure how you would go about doing that, but that's all it should need.
If it has tracks, tires or tits, its gonna cause a problem.
"Everytime someone "upgrades" a D35, an angel looses its wings."
"Dizzy" - What SnoopDog would call a Distributor if he was a mechanic. I cringe every time I hear this moronic term
Originally Posted by Warren Zevon
Send lawyers, guns and money. The **** has hit the fan...
92, 4.0, AW4, 8.8, D30, 15x10, 37's, SOA etc, etc
92, 2.5, 30, 8.8, 4.88, Locked, Winch, 15x8, 35's, 3.5" (RIP)
notmyj is offline
post #3 of 4 Old 04-27-2010, 06:57 PM Thread Starter
muddigger0829
ok thanks for the responce. Im going with a carb because i am a fan of them and absolutly hate working on the newer stuff. i figured the pump would be too much for the carb but wasnt 100%. also i was looking at the holly carb that is built for off roading.
post #4 of 4 Old 04-27-2010, 07:31 PM Thread Starter
muddigger0829
ok next question....
how did yall do the wireing on the engine so all the factory gauges work?
305 Chevy Swap TeeJeep YJ Wrangler Technical Forum 26 06-07-2013 03:20 PM
chevy 4.3 swap Fastbeeatch YJ Wrangler Technical Forum 7 04-06-2012 05:22 AM
chevy 350 swap James2004 TJ Wrangler Technical Forum 5 03-03-2010 10:34 PM
Chevy 350!! Carb Or Fuel Injection DARRTILLM YJ Wrangler Technical Forum 1 07-09-2008 11:08 AM
4.3 chevy swap how to Yule16MET YJ Wrangler Technical Forum 8 09-01-2006 07:43 PM
