cant turn engine by hand - Page 2 - JeepForum.com
post #16 of 25 Old 06-23-2010, 06:34 AM Thread Starter
wanabejeeper
1987 YJ Wrangler
So just an update. Work on the heap has been slow as I tear everything back out. Tranny, TC and Flex plate are out but still no engine rotation. The TC does fit nicely into the bellhousing and spins fine. No grinding or other indications of damage to the Tranny... This weekend I'll get an engine hoist and pull the engine back out and onto a stand... Sigh.
On the upside I jumped on an 89 YJ Sahara I saw for sale. In perfect shape very little rust with a rebuilt engine and tranny. 3500
87 YJ The Original!
It goes in that barrel you wheel out to the street once a week.
My build thread
wanabejeeper is offline
post #17 of 25 Old 06-24-2010, 06:39 AM
2cjs
2cjs's Avatar
I might be out of place here but did you put the spark plugs in the engine yet?
83 cj-7 258c.i., 727auto, d300, d44 front, d60 rear
92'yj 4.3(roller) tbi chevy,700r4 ,soa, 35-12.50-15 maxxis bighorns
89'yj wife's jeep 4.2l stock ,2"bl ,31-10.50-15 bfg mud terrains
work smarter not harder
2cjs is offline
post #18 of 25 Old 06-24-2010, 08:23 AM Thread Starter
wanabejeeper
1987 YJ Wrangler
no its completely open.... I'm going to drop the pan first and inspect before I pull the engine. maybe I can find something that way.
87 YJ The Original!
My build thread
post #19 of 25 Old 06-24-2010, 08:31 AM
MJMPC
Y ou said you had the motor on a stand. What did you do to the motor while it was out?
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #20 of 25 Old 06-25-2010, 06:51 AM Thread Starter
wanabejeeper
1987 YJ Wrangler
This was a fresh reman engine that I was installing to a rebuilt tranny If you read the whole thread you will get a better idea of where I'm at. At this point I'm updating more for documentation purposes then anything else. Theres no question the engine suffered some sort of problem from my installation of the tranny the question is what and how bad.
87 YJ The Original!
My build thread
post #21 of 25 Old 08-31-2011, 05:27 PM
oldtime_ironman
Willing to bet the tranny install shoved the crank forward hard enough to bind. Can't imagine what else on a fresh engine. If I didn't see anything obvious with the pan and timing cover off, then I would whap the front of the crank a few times with a BFH and see if that frees it up.
oldtime_ironman is offline
post #22 of 25 Old 09-04-2011, 03:31 PM Thread Starter
wanabejeeper
1987 YJ Wrangler
Well smack my *** and call me stupid. Turns out it was the pulley bolts around the balancer. They were contacting the block and preventing the engine from turning. Just about the dumbest thing I've ever done....
Well at least its fixed and it wasn't the bearings
87 YJ The Original!
My build thread
post #23 of 25 Old 09-04-2011, 03:44 PM
oldtime_ironman
Well, I gotta admit that I've never seen that one before. That woulda messed me up too. Never heard of it. So I guess you should feel good and party!
post #24 of 25 Old 09-04-2011, 10:21 PM
MoparFreak69
That'll do it! Must have been quite overly long for the job to go through everything and hit the block hard enough to prevent turning. I would inspect the damper closely to make sure it didnt get tweaked as it probably had a lot of pressure on it as well. If all is good toss her back together and get her running!
90 YJ 5.2 Magnum, AX-15, 231 SYE'd
D44 front, welded/trussed AMC20HD rear. 4.56 gears soonish.
Western 6 lug aluminum wheels, with 35x12.50x15 Wrangler MTRs
MoparFreak69 is offline
post #25 of 25 Old 09-04-2011, 11:52 PM
kahanabob
hey, this thread is over a year old!!!!!
kahanabob is offline
Tj front wheels hard to turn by hand. Erikxj91 TJ Wrangler Technical Forum 5 03-28-2010 08:41 AM
Left hand turn signal issue? cormac827 YJ Wrangler Technical Forum 13 12-03-2009 09:10 AM
Left hand thread, which way to turn? provinT13 YJ Wrangler Technical Forum 2 08-02-2008 03:35 PM
Wheel hubs: how hard to turn by hand? Fett TJ Wrangler Technical Forum 8 05-15-2006 12:01 PM
No right hand turn signal shenry YJ Wrangler Technical Forum 10 04-09-2005 11:58 AM
