Cant snap my soft top - JeepForum.com
post #1 of 9 Old 11-09-2013, 08:59 AM Thread Starter
ReDinTX
I replaced the snaps on the window rail clips, and when I tried to snap the top on them, i dont have enough slack! the PO replaced the plastic studs with bolts, on the windshield brackets, but when i removed the bolts, it did not free up any slack for the top. I have tried in the warm sun and still no luck, i am at a loss.
The top flaps in the wind on the highway and not only is very annoying but the snaps are also rubbing spots on the window rail.
Also, while looking for advice, I saw mention of a tailgate bar, which i do not have. anyone have any pics of theirs?
suggestions?
-ReD
Fire Lieutenant/Paramedic
San Antonio, Tx
'90 Yj 4.2L 5spd
ReDinTX is offline
post #2 of 9 Old 11-09-2013, 09:21 AM
irnmadn88
That bolt will have to go. IIRC, there should be enough tension in the top to keep the window rail in place without the bolts.
Look up YJ soft top parts on q-tech. They are not expensive.
A little spray lubricant in the snap head.
If the warm sun does not help, try getting the top wet.
Snap one side, go to other side and pull along the entire edge. Unsnap first side, snap other side, repeat pulling on top from other side. Then try to get the whole thing snapped.
YJ soft top tailgate bar:
http://www.quadratec.com/products/11033_301_07.htm
irnmadn88 is offline
post #3 of 9 Old 11-09-2013, 09:27 AM
Beaveranger
The only way to get more slack is to get it warm. Wet helps some, too. Especially when setting it out in the sun to warm. Harder to do in winter months, obviously. I have always found that my top never snaps all the way around. It is always snug and keeps rain out tho. Snaps rattle when driving. I just chalk it up to one of those individual quirks about my Jeep in particular.
This is the tailgate bar
It slides out like this
Attached here
Yeah, mine is pretty old. 18 years to be exact
Hooks to the jeep here
There's only one thing I hate more than lying. SKIM MILK
Which is water that's lying about being milk....
~Ron Swanson~
Beaveranger is offline
post #4 of 9 Old 11-09-2013, 09:28 AM
Old4X
1990 CJ7
In the fall when I reinstall my top, it has shrunk to the point nothing firts.
I park it in full sun, and put an electric space heater in the rear bed. After about an hour I have plenty of slack everywhere and have no problems fitting everything and getting all snaps fastened.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #5 of 9 Old 11-09-2013, 10:32 AM Thread Starter
ReDinTX
The snaps will fir together, i just dont have enough slack to do it. I removed the bolt thinking it was pushing the rail out too wide, nope. didnt come in any when i removed the bolt. I then raised the rail up slightly to be able to snap the snaps, but when I lowered it back in place, they all popped off
Attached here
so on my rear window panel, theres a plastic "tube" for lack of a better word, thats in a sleeve at the bottom, is that what slides into this tailgate bar?
-ReD
San Antonio, Tx
'90 Yj 4.2L 5spd
ReDinTX is offline
post #6 of 9 Old 11-09-2013, 11:44 AM
Beaveranger
Just flip up your back window. Should be a rubber "tube" sewn in near the bottom.
Slides into here on the tailgate bar
Slider her in like this
Hope this helps
~Ron Swanson~
post #7 of 9 Old 11-09-2013, 02:12 PM Thread Starter
ReDinTX
pics are worth a thousand words! Thnx dude, helps a BUNCH!
-ReD
San Antonio, Tx
'90 Yj 4.2L 5spd
ReDinTX is offline
post #8 of 9 Old 11-09-2013, 02:48 PM
Beaveranger
I agree. And no problem.
~Ron Swanson~
post #9 of 9 Old 11-10-2013, 06:27 PM
lander2312
Plug in a small area space heater and let it sit there foe an hours or so...you should have plenty of space then.
lander2312 is offline
