Can't shift into any gear!!! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Can't shift into any gear!!!
The Cure for your Tie Rod Roll!Offset Tie Rod Kit From RuffStuff!SPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!
Unread 09-18-2012, 01:13 PM   #1
carloricci1
He clutch has se play and can't shift. Does anyone know if it's the slave cylinder?
carloricci1 is offline   Reply With Quote Quick reply to this message
Unread 09-18-2012, 01:18 PM   #2
Anticanman
The Thunder Chunky
Anticanman's Avatar
Will it shift when the jeep is off?
Luck Favours The Prepared
"Whiskey is for drinking, Water is for fighting over" - Mark Twain
Originally Posted by timatoe View Post
Hmm, that's kinda like asking how much is it to buy a red car....
Anticanman is offline   Reply With Quote Quick reply to this message
Unread 09-18-2012, 01:21 PM   #3
jaycal3
jaycal3's Avatar
When i lost my slave on my last jeep I had fluid everywhere underneath and couldnt shift at all... Dont know what you drive so I dont know if its internal or external...
93 YJ, 6 cyl,3.5" BDS,1" Prothane BL,1/2" booms, 33" Mickey Thompson MTZ on MT Beadlocks.
Do your part for Leukemia research - help find a cure.
http://mskcc.convio.net/goto/Jay_Calabrese
KCCO
jaycal3 is offline   Reply With Quote Quick reply to this message
Unread 09-18-2012, 01:35 PM   #4
carloricci1
I dont know if I'm replying right, new at this but anyways. Yes it does shift when it's off. That how I got it run on 2nd till I got home. Now the weird thing is that at that time the clutch pedal was pretty low but when I parked it and left it for a fre hrs then it was back up and working
Unread 09-18-2012, 01:37 PM   #5
carloricci1
93 Wrangler stick shift. No leaks or I havn't seen any so far
Unread 09-18-2012, 01:41 PM   #6
jokerchief462
Wild Wheeler
jokerchief462's Avatar
Yeah typical wrangler clutch problem. It is losing pressure could be the slave could be the master. Since it is a sealed system it has to leak somewhere. Mine did the hot and cold no work then works a couple days before the leak showed up under the bellhousing. So you need to take a look under the bell housing and the cab where the peddle pushes the piston for the master it will leak down the firewall by the pedal.
jokerchief462 is offline   Reply With Quote Quick reply to this message
Unread 09-18-2012, 01:56 PM   #7
carloricci1
Would air in the lines cause that? Or that has nothing to do with it?
Unread 09-18-2012, 03:00 PM   #8
WakeDoctor
It could be air in the lines but the question is how did it get there. Probably a leak. You can bleed the system of air with another person, I believe there is a write up on here somewhere, and if it comes back/doesn't fix it you might need a clutch replacement.
WakeDoctor is offline   Reply With Quote Quick reply to this message
