Can't retrieve error codes (91 4.0l) - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Can't retrieve error codes (91 4.0l)
Free shipping on slip yoke eliminator kits New lower PriceNew! JK/U skid plate system.FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome Effect
Unread 02-17-2013, 02:44 PM   #1
idskot
I have a '91 4.0L Automatic. I've been able to get codes from it in the past, and until today I hadn't had a check engine light issue.
2 months ago a yoke strap busted, and since then I've been saving up the money / time to get an 8.8 installed. I started it up today to move it (I've been starting ti up every week or so and letting it idle for about 15 minutes during the same time I start up my boat.) I started it up today, started fine. Drove it the 10 or so feet that it needed to go when I realized the check engine light had stayed on. Any attempt to retrieve failed. (See picture)
I disconnected the battery for about 10 minutes. When I reconnected it, I got error codes (12, 33 -- which are normal) and nothing else. I started and it, again, had no check engine light. I turned it off. Came back to it a few hours later and the check engine light is back on. And, again, any attempt to get the code(s) doesn't work.
Anyone have insight?
http://www.youtube.com/watch?v=EkhuJq2DZCI
EDIT:: From what I can gather, it's running fine. I don't have any of my tools here to test fuel pressure or anything similar. But everything seems to be working..?
idskot is offline   Reply With Quote Quick reply to this message
Unread 02-17-2013, 05:28 PM   #2
idskot
bump
Unread 02-17-2013, 07:20 PM   #3
idskot
Night bump?
Unread 02-17-2013, 10:03 PM   #4
jokerchief462
Wild Wheeler
jokerchief462's Avatar
Yeah I see what your getting. Try 3 on off and then on and see if it reads. Just a guess I got an 88 no codes but I did a lot of those checks working at AZ.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline   Reply With Quote Quick reply to this message
