cant find tire size online anymore - JeepForum.com
post #1 of 13 Old 04-26-2009, 08:14 AM Thread Starter
CreepyCrawler95
title explains it, ive got a set of TSL BIAS that are 33x13.50 15. well i got a screw stuck in my back left tire and it just barely punched through the top wall as well as a whole lug... i can hear air leaking and ive been trying to find the same size tire online at tirepackage.com which is where i ordered them from in the first place. well apparently they dont have this exact size anymore. does anyone know where i can get this tire and size for cheap?
CreepyCrawler95 is offline
post #2 of 13 Old 04-26-2009, 10:55 AM
xeroid81
4wdhardware.com but don't know about cheap. You'll have to check around to compare!
xeroid81 is offline
post #3 of 13 Old 04-26-2009, 11:10 AM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Joe Dillard is offline
post #4 of 13 Old 04-26-2009, 04:02 PM Thread Starter
CreepyCrawler95
ive checked those places, they have 33x12.50 and 33x13 but no 1350s. i guess ill have to call to be sure
post #5 of 13 Old 04-26-2009, 04:28 PM
Opihi59
from here it gets rough
Opihi59's Avatar
Creepy--this went thru the sidewall, so it's not repairable?
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #6 of 13 Old 04-26-2009, 07:31 PM Thread Starter
CreepyCrawler95
no it went through a top center lug and through the top wall
post #7 of 13 Old 04-26-2009, 07:58 PM
Solus
if it was just done on the top you can patch it.
Solus is offline
post #8 of 13 Old 04-26-2009, 08:05 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Here is a link to the Interco TSL Bias size availability chart from Interco's website.
http://www.intercotire.com/tires.php?id=10&g=1
They don't list that size (that I could find) but if it is on there, Google the number listed in the "Interco Number" column and you should be able to get something. Most tire retailers use Interco's numbers as well.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #9 of 13 Old 04-26-2009, 08:05 PM Thread Starter
CreepyCrawler95
i thought that was a temporary fix though
post #10 of 13 Old 04-26-2009, 08:06 PM Thread Starter
CreepyCrawler95
well i dont see that size on there and thats what i have
post #11 of 13 Old 04-26-2009, 08:13 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Google your size and put "Interco Number" in the search bar to see if you can find their number. Then you can search again using that number to see if there's a retailer who may still have some.
Max
Mean Max is offline
post #12 of 13 Old 04-26-2009, 08:19 PM
Solus
If you get yourself a good quality patch then it will last forever. You can even go as far as taking it to a tire shop and having them put a patch on the inside. It will be much cheaper then getting a new tire and you wont have a difference in circumference of your tires.
Solus is offline
post #13 of 13 Old 04-26-2009, 08:32 PM Thread Starter
CreepyCrawler95
sounds good to me ill do that within the next few days...no money...never any money. i guess its price we yj onwers must pay
Help! Can't seem to find this wheel online whackicee YJ Wrangler Technical Forum 12 07-08-2009 04:02 AM
JK Online Gallery - Lifts Cataloged By Manf and Tire Size RJ999 JK Wrangler Technical Forum 6 11-08-2008 07:32 AM
Where can I find a Soft Top and tailgate bar online? webdave JK Wrangler Technical Forum 5 05-19-2007 12:28 PM
Where can I find a TJ to buy..online? firefitr26 TJ Wrangler Technical Forum 5 05-27-2004 01:11 AM
