Can't find the ID plate and paint code
| Rock Krawler Suspension's for BLOW OUT prices!!! | Great deals on Mickey Thompson Tires @ Jeephut.com | RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com |
#1 | |
I need to paint a fender and am looking for the factory paint code which should be on an ID tag somewhere. There are two tags, one on either side of the firewall but neither tag looks like the example in the Haines manual. My '88 YJ is the Sahara version with the olive green paint color.
Thanks, Bruce
#2 |
on the id tag near the master cylinder, the paint code will be on the second line from the bottom. it should be after APA and begin with a p and will be 3 digits. you can then go here to find out exactly what it is http://www.autocolorlibrary.com/cgi-bin/search/search.pl
#3 | |
Thanks again, Bruce |
#4 |
Call your local Jeep dealer. They should be able to run your VIN# and get the paint code that way. My buddy works at the local dealer and he ran it in their program and it worked for my 88'. Then I just called my paint supplier and gave him the paint code and he mixed it up for me.
1988 Wrangler, 2000 Cherokee Freedom Edition, |
#5 | |
Here's what it says: CV-81- 532732 798 31 TN-BL- BFF CON RP SAH ROM FOG CAN FMD SSB FCT Edit: Well, I can't get the numbers to line up as they appear on the tag. The 532732 798 31 BFF CON RP SAH ROM CAN FCT are all on the right side of the plate. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
