cant figure out my driveline angles - JeepForum.com
post #1 of 7 Old 04-01-2013, 02:39 PM Thread Starter
lancer27
okay so i am about as dumb as you can come when it comes to math. now ive been reading for ever trying to figure out how to get my driveline to work with out vibs and im getting no where... so i am running a 2.5in RC suspension lift with an AA sye and a TW CVDS. i have pictures of where i measured and what numbers i get. but i just cant figure this out and its making me frustrated beyond belief at this point. so can you guys help me out. thank you.
97 tj i6 3.5 RE superflex lift. hp dana 30 4.56 gears ausie up front. dana 44 33spline alloy usa shafts arb rear. tom woods supper short sye and matching cv ds. 35x12.50x15 goodyear MTR's with kevlar. york OBA system. Metal Cloak High Arch tube fenders!(my favorit mod!!!)
lancer27 is offline
post #2 of 7 Old 04-01-2013, 02:44 PM Thread Starter
lancer27
sorry for huge pics.
lancer27 is offline
post #3 of 7 Old 04-01-2013, 02:59 PM
jonny93yj
Looks like your pinion is between 11 and 12 and your d/s is about 22.
jonny93yj is offline
post #4 of 7 Old 04-01-2013, 03:35 PM
bogleparsons
I read 22 for drive shaft and 5 for pinion.
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
post #5 of 7 Old 04-01-2013, 03:39 PM Thread Starter
lancer27
so does that mean i need to add an additional 10* shims to the existing 6* shims that are already in place? this is where i am confused. i feel as if my diff is not 11* off from the ds.
lancer27 is offline
post #6 of 7 Old 04-01-2013, 09:04 PM
jonny93yj
You're right. Not sure how I ended up with 11 or 12. I just set mine up last weekend but i just cut my spring perches off and welded some new ones on in the appropriate spot.
post #7 of 7 Old 04-01-2013, 10:52 PM
DirtKar
Maximum Effort
DirtKar's Avatar
You would be better served to take your measurements on the flats of the yoke vs the case. The pinion yoke ears should be horizontal when measuring. Use that number (angle) and match it up against the drive line angle. Split the difference and you will have the number you are looking for. Not a bad idea to subtract a degree or two from the final number to allow for the torque created on acceleration.
Luck Favours The Prepared
YJOTM JULY 2014
DirtKar is offline
