Can't decide which method to achieve clearance for 33's - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Can't decide which method to achieve clearance for 33's
Artec July Promo - FREE STUFF, SHIRTS, & SHIPPING!PRP Seats & Harness at CCOR 706-207-4140Jeep Wrangler Complete Gear Upgrade Kits with Installs and
Unread 02-04-2014, 06:25 PM   #1
YJjeeper1
So I've done a ton of research on this subject but it's time I ask for some help. I am planning on getting a lift kit to fit 33's. However I really want to avoid the added expensive of a sye and cv driveshaft. So my choices are either to go with the 4 inch rubicon express lift and pray it doesn't mess with my driveline angles or get a rubicon express 2.5 with a one inch body lift. From my research It seems the 2.5 with the 1 inch bl might be the right choice for me. However I have a few questions for people with this setup. Do the 2.5 inch leafs really flex better than a 4 inch. Also with this setup is a sye usually not required? I don't Mind a tc drop but really trying to avoid a sye. I understand the price of the re 2.5 + the 1 bl will be the same price as the 4 inch re kit, so I need some input. Thanks
YJjeeper1 is offline   Reply With Quote Quick reply to this message
Unread 02-04-2014, 06:30 PM   #2
88hatchy
Get a motor mount lift to help get rid of driveshaft vibrations with the 2.5" springs.
1997 TJ - Current project: Simple-ish build
1988 Civic Hatch - Runs 12's, gets 30 mpg
88hatchy is online now   Reply With Quote Quick reply to this message
Unread 02-04-2014, 06:34 PM   #3
YJjeeper1
Ok but as far as a 2.5 + 1 inch bl, is a tc drop usually enough on it's own? Looking for people's experiences here, thanks.
Unread 02-04-2014, 06:36 PM   #4
88hatchy
You can get away with not using a transfer case drop if you install a motor mount lift. You could possibly have shifter issues if you use a transfer cased drop with a body lift.
Unread 02-04-2014, 07:03 PM   #5
lil_joe
I have a 4" lift with 1.25 Boom shackles and 1" BL, with the TC drop, I have not had any vibes since install 4 yrs ago. No SYE needed.
Mike
____
lJeepl
--[.]IIIII[.]
Obsession is a word the lazy use to describe the dedicated
HER's: 92 YJ 4" RC 1.5 RC Booms, 1" BL on 33's
MINE's: 97 ZJ 5.2 Upcountry Limited Project 2" RE BB on 265/75 Mud Dogs, Locked front LSD rear, 242 swapped T-Case, RC Quick Disco's
www.virtualjeepclub.com/
lil_joe is offline   Reply With Quote Quick reply to this message
Unread 02-04-2014, 07:14 PM   #6
jaycal3
jaycal3's Avatar
I have a BDS 3.5" and 1" Prothane BL with no SYE. Just a tc drop. No vibes. Clear 33's no problem.
93 YJ, 6 cyl,3.5" BDS,1" Prothane BL,1/2" booms, 33" Mickey Thompson MTZ on MT Beadlocks.
Do your part for Leukemia research - help find a cure.
http://mskcc.convio.net/goto/Jay_Calabrese
KCCO
jaycal3 is offline   Reply With Quote Quick reply to this message
Unread 02-04-2014, 07:52 PM   #7
Anticanman
RIP one good jeeper
Anticanman's Avatar
Try BDS 2", 1/2" Besrk booms, 1" BL and some TJ flares in the rear and some flat fenders up front.
Luck Favours The Prepared
Anticanman is offline   Reply With Quote Quick reply to this message
Unread 02-04-2014, 08:56 PM   #8
DirtKar
I pledge allegiance.
DirtKar's Avatar
3.5" BDS w/ 1/2" booms, 1" bl, 1" MML, NO TC drop on 33's. NM, I have an SYE too. What makes you not want one? Benefits outweigh the cost&effort to install one. Just break that stock driveline once... Ask me how I know. This shot is with Revolvers up front which are about 1/2"-3/4" lower than the booms that are back on now.[/URL]
YJOTM JULY 2014
DirtKar is offline   Reply With Quote Quick reply to this message
Unread 02-04-2014, 10:26 PM   #9
AZdEvilYJ
RIP Anticanman
AZdEvilYJ's Avatar
4" RUbicon express lift. I had a temporary t case drop in while I got my sye together
'95 YJ 2.5L
March '15 YJ of the Month!
Exiled Offroad - Arizona
My Build Thread
http://www.jeepforum.com/forum/f22/a...nally-1575209/
AZdEvilYJ is online now   Reply With Quote Quick reply to this message
Unread 02-05-2014, 10:50 AM   #10
RCwheelin
Hey what lift do you have on your rig now to clear 35's? I'm guessing it's the same lift but flat fenders and larger wheel arch?(sorry to be offtopic)
93' YJ
RCwheelin is offline   Reply With Quote Quick reply to this message
Unread 02-05-2014, 11:54 AM   #11
AZdEvilYJ
RIP Anticanman
AZdEvilYJ's Avatar
Exactly. Same lift with Metalcloak Arched fenders and PoisonSpyder crusher corners with the TJ wheel opening
'95 YJ 2.5L
My Build Thread
Unread 02-05-2014, 03:41 PM   #12
StanF
+1
This is the ticket...I would add the MML as mentioned above to help your driveline angles.
This is basically my exact setup (other than the flat front fenders)
StanF is online now   Reply With Quote Quick reply to this message
Unread 02-07-2014, 07:52 AM   #13
jbeebe
With the 4" lift and the included TC drop, you'll be fine. You MOST LIKELY won't get vibes.
91 YJ. 4.0, 4.10's, 33's, 4" springs, 3/4" booms, 1" BL, 1" MML, d30 aussie locker, hand throttle, posi-lock, full cage, bumpers/rocker guards/engine skid, winch.
jbeebe is offline   Reply With Quote Quick reply to this message
Unread 02-07-2014, 09:33 AM   #14
Lemoore-on
I'm running 33's with OME 2.5" .5 booms in front/1" booms in rear with MCE front flat fenders & TJ flares in the rear. The TJ flares allow you to go to bigger tires with less lift because You cut the wheel wells bigger.
You might get away with no Tcase drop & no vibes. But I still recomend a SYE.
Mike
92YJ with some stuff done to it.
Lemoore-on is offline   Reply With Quote Quick reply to this message
