canadian yj - Page 2 - JeepForum.com
post #16 of 21 Old 03-24-2005, 12:21 PM
Wif
Wif's Avatar
Originally Posted by lord_retro
the only pain with swapping speedos is that his original will actually have the original mileage on the jeep... no big deal though... the speedo comes off really easy my pulling the gauge cluster plastic (it's like 3 screws" and then you can disconnect the gauge... if you don't care about having the wrong mileage, then just put one in from the wreckers... otherwise you could just try changing the faceplate... i wouldn't know how to do that though, but i'm sure it's not that hard once you have the gauge out.... or you can just suck it up and look at the small numbers instead of the big ones!!!
reading the small instead of big (kms to mph) means if you make a mistake at least you'll be driving slower than the posted limit
Here in Canada I drive a '65 Stang which has only mph. I can't tell you the number of times I've sped off down the road before realizing I was going too fast (honest officer .. )
Formally 88Jeepster
Who's in front ?
Ridin' topless again .. sweet !!
Wif is offline
post #17 of 21 Old 03-24-2005, 12:37 PM
Meister_jeep
Just change the facing of the speed it cost almost nothing or leave it as is you can just read the small number and after a week you get used to it. Now I was wonder why the hell someone would think that the voltage indicator would have a different unit cause the only damb unit to mesure voltage is in VOLTS lol. As for the YJ's with d44's in canada I've only seen one around here and never really heard about the dealers offering them with d44's. It would have been a nice thing though if they did.
1988 YJ 4.2l
__________________________________________________ __
WEBER CARB
NUTTER BYPASS
FIBERGLASS BODY TUB
BDS 3.5
SYE+CV SHAFT
FORD 8.8 WITH 4.10 GEARS, DISK BRAKES
33x12.50 GOODYEAR MT/R's ON AR767 15x8
CUSTOM STANLESS STEEL DISCO`s
JUICEBOX.
LED TAIL LIGHTS
$10 homemade POSILOCK
(IN THE WORKS THIS SUMMER)
-Custom front and rear bumpers
-HEI UPGRADE
-4.0 HEAD
-MIGHT TRY THE JEEP INJECTION KIT FROM WEBER
Meister_jeep is offline
post #18 of 21 Old 03-24-2005, 03:28 PM
JustPassinThru
What about emissions?
This is interesting - back when the dollar/cd$ exchange was so wonky, I was considering buying a Canadian used CAR over there and bringing it back. There were some bargains in the Fort Erie area....
The dollar/canadian $$ relation is going to fluxuate again, bank on it. It would be great to be poised to save some money.
JustPassinThru is offline
post #19 of 21 Old 03-24-2005, 03:37 PM
BackRoadJPin
1995 Wrangler
BackRoadJPin's Avatar
Well like I said [QOUTE]Voltage is universal I believe *correct me if im wrong people*[/QUOTE]
I do not know about your jeep, but mine *canadian* does not indicate what the measuring units are with the exception of the speedo.
Back Road Jeepin
BackRoadJPin is offline
post #20 of 21 Old 03-28-2005, 08:31 AM
sixdoubleseven
My YJ from Canada has the oil pressure and temp in metric measurements. Volts are obviously the same as the US YJs.
I also have Daytime Running Lights (DRLs)
and a factory engine heater plug thing.
sixdoubleseven is offline
post #21 of 21 Old 03-30-2005, 06:55 PM Thread Starter
rmjuice9
thanks for all the info guys. I have checed with a garage here in PA that deals with a lot of eropean cars and they said the spedo will pass inspection even if it it in km's. according to Penn Dot i have to pay no duty all i have to do is pay Pa state tax. Correct them if they are wrong cause it just seems to easy to me. I am going up to look at it this weekend and hopfully all goes well then i will finally be a YJ owner.
rmjuice9 is offline
'89 YJ - Canadian CheapSunglasses YJ Wrangler Technical Forum 27 02-15-2009 09:49 AM
Canadian Help! Okanagan_TJ Wrangler General Discussion 17 12-16-2008 06:36 PM
Canadian YJ Owners iowajeepers YJ Wrangler Technical Forum 15 08-26-2008 11:14 PM
Canadian Jeep Shane64 TJ Wrangler Technical Forum 26 03-16-2007 03:53 PM
Canadian YJs? ZonaWrangler YJ Wrangler Technical Forum 20 01-14-2005 03:20 PM
