canadian winters !!! - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > canadian winters !!!
NOTCH CUSTOMS - Max Clearance Fender FlaresIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineROCKRIDGE 4WD Supports our Service Members! Military Disc
Unread 12-11-2006, 12:44 PM   #16
toates89
1989 XJ Cherokee
i thought mudders would help get you out of 2 foot snow better then at's but would have less traction
toates89 is offline   Reply With Quote
Unread 12-11-2006, 12:49 PM   #17
keithert
keithert's Avatar
In deep snow the muds will do better than AT's but on roads with just a bit of snow the at's will do better because their treads have sipes in them to channel water out and have more edges to bite into the snow.
Current: 2005 Wrangler Unlimited - Past: 90 and 92 Trackers and 98 Wrangler SE
keithert is offline   Reply With Quote
Unread 12-11-2006, 01:13 PM   #18
jimwww
nope.. Mud terrains don't even have a snow symbol on them.. the snow fills up on them and spin...
jimwww.com
2001 Jeep TJ Yellow, 4.0L, 6cyl, 5spd Trektop NX Frameless
Past: 2- Yj, 1- Tj, 2- Zj, 2- Xj, 1-WK, 1-WJ,
jimwww is offline   Reply With Quote
Unread 12-11-2006, 04:27 PM   #19
toates89
1989 XJ Cherokee
oh because that snow symbol does so much
Unread 12-11-2006, 05:09 PM   #20
03Wrangler
the snow symbol gives traction about 10x better then the no snow symbol....
kind of like red jeeps give you better gass millege then blue jeeps, and yellow jeeps let you never get stuck.....
get the snow symbol and a yellow jeep, you'll be all set....
FOR SALE
Olympic Trunk for 03 TJ
03Wrangler is offline   Reply With Quote
Unread 12-11-2006, 07:58 PM   #21
toates89
1989 XJ Cherokee
do you think if i draw a snow flake with permenate red marker not black would it give the same result or no and damn i have a blue jeep that gets bad gasmileage so bad that i just got home from the long walk because i ran out of gas
Unread 12-11-2006, 09:54 PM   #22
Kenabeeker
Hello Fellow Londonite
Hey
I noticed your nickname. You are from London I am guessing? I am too. I have a 4.2litre in mint condition. Perhaps we can go mudding sometime and you can get used to your 4x4. I have found that to be the best way to get better in the snow. Go get yourself stuck with a friend who has a winch. After a couple trips through some rough spots, you will be good with the snow. Put her in 4x4 and climb over some snowbanks in a safe spot or in your laneway is always good too.
In the snow, normally the trick is keeping your tires from slipping, so if you are driving standard. Practice rolling over feathering the clutch so that you can roll over snowbanks without spinning the tires. Once you can do that you should be comfortable in anything Canada can throw at you. Including our lovely little storm we had last week.
P.S. You will be amazed at what a good set of Snow tires will do for your traction.
Kenabeeker is offline   Reply With Quote
