Can you watch my carb vid? - JeepForum.com
post #1 of 4 Old 06-22-2014, 11:33 AM Thread Starter
geofri
https://www.youtube.com/watch?v=HYViCqb5KjQ
I was never happy with my carb rebuild, also having trouble with the choke. I think my vacuum diaphragm is bad too?
Opinions on how it's working?
geofri is offline
post #2 of 4 Old 06-23-2014, 02:52 PM
rbthompsonv
cant be positive.. but it looks like your venturi is a little clogged, and rather than a nice aerosol of gasoline, you're getting sort of a stream of it.
Have you tried boring them out to 0.32 inches?
The other option is to swap to a motorcraft 2100 or 2150... I just did and am REALLY happy with it so far. WAY more power... fuel economy might or might not be... i just dialed it in, so, we'll see
also, is that fully warmed up? Your airhorn should be all the way open... not 3/4 open
rbthompsonv is offline
post #3 of 4 Old 06-23-2014, 02:53 PM
rbthompsonv
also, yes, your choke is leaking (when you compress it and seal the vacuum, it should stay wherever you left it, not slowly move forward)
post #4 of 4 Old 06-23-2014, 03:19 PM
Mike Romain
Is the power wire hooked to the choke? That choke does not appear to be working, it is 3/4 closed with the fast idle cam on the first step. The choke vacuum pull off is also bad.
After 5-7 minutes of running, that choke plate should be wide open. The vacuum pull off leaking makes the mix a bugger to set, but that has no bearing on the choke not opening, it is for the first cold start.
Mike
Mike Romain is offline
