Can a transmission be welded? - JeepForum.com
post #1 of 20 Old 12-04-2013, 11:33 PM Thread Starter
91YJ-98TJ
I went to check my transmission fluid, and the fill plug was pretty tuff to get off, so topped it off and went to put the plug back in, and being a dumb *** figured it should go on just as tight as it was getting it off and I broke of the top part of the threaded hole where the plug goes in. I keep trying to post pics but there too large. So can this be welded or what do I do from here?
91YJ-98TJ is offline
post #2 of 20 Old 12-05-2013, 12:10 AM
SeanB95YJ
the material is (or SHOULD be) cast aluminum... it CAN be welded, but from my experience, would need to be TIG welded by a pro.
Whether or not YOUR particular break can be repaired I guess would depend on the extent of damage and the location. Only thing I can suggest would be to drain it, remove it and bring it to a good welding shop and ask them.
Good luck
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #3 of 20 Old 12-05-2013, 12:29 AM
baktie_91YJ
Its either cast aluminum or cast magnesium, dont remember which, both of which can be TIG welded. Unless you have a nice TIG setup and are extremely comfortable doing it then I would bring it to a shop
baktie_91YJ is offline
post #4 of 20 Old 12-05-2013, 08:34 AM
tom_sprecher
Even when you try to TIG cast aluminum it is almost impossible to clean it enough to keep worn holes from forming while welding it. Ask me how I know.
Tom
tom_sprecher is offline
post #5 of 20 Old 12-05-2013, 11:22 AM
superj
liquid metal it, ha ha ha. sometimes that works for stuff, and sometimes not. just depends on the stresses that area of the transmission deals with
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #6 of 20 Old 12-05-2013, 02:22 PM Thread Starter
91YJ-98TJ
Thanks everyone. I've asked around town and a few people recommended the same guy, but when I went by he hasn't been there. I figure if he doesn't feel confident doing it just trying jb weld and hoping for the best because either way I'm looking at a new transmission. Right?
Think I probably ended up cracking it when taking the plug out since I did have to use a breaker bar and then just realized what happened when I tried to tighten it.
post #7 of 20 Old 12-05-2013, 04:00 PM
Steve707
If its aluminum you'll need a high frequency machine to weld it.
Steve707 is offline
post #8 of 20 Old 12-05-2013, 10:40 PM
nzpete
What is a high frequency machine?
To me, RC is kind of the Harbor Freight of springs. Sometimes you get a good deal and sometimes you don't.
nzpete is offline
post #9 of 20 Old 12-06-2013, 08:01 AM
Steve707
It'll weld AC and not just DC.
Steve707 is offline
post #10 of 20 Old 12-06-2013, 08:19 AM
bigbossd1030
Of your tranny was in nice shape, can I suggest getting a used one from a JY, having it gutted and put your parts inside. Or get a used one and when the gears give er, swap yours in. Just an idea,
Should be cheaper than a reman or a new one.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #11 of 20 Old 12-06-2013, 08:46 AM
nzpete
Most stick welders are AC.
nzpete is offline
post #12 of 20 Old 12-06-2013, 09:02 AM
Steve707
You plug them in to AC outlets, but you don't weld steel with AC. Stick welding is DC+.
Steve707 is offline
post #13 of 20 Old 12-06-2013, 09:26 AM
willawolfe
Why not get a new trans on cl or junk yard. Aside from your labor it may cost same as paying someone who might be able to fix it
willawolfe is offline
post #14 of 20 Old 12-06-2013, 11:31 AM
fishadventure
A photo of the break would be handy. Welding will work but you won't do that with a stick welder... Go to a pro welding shop as suggested.
However, what *I* would do is find a "core" or otherwise blown up/free/cheap tranny and just swap the cases.
Shackles and D-rings: different things!
Cranking IS turning over
fishadventure is online now
post #15 of 20 Old 12-06-2013, 03:25 PM
Norcal_chris
Norcal_chris's Avatar
Um what?
A standard transformer-based arc welder nearly always produces AC output. DC is the perferred method for welding , but tons of people weld steel with AC output buzz boxes
I welded up my transfer case that was halfway cracked and the ears broken off with a Mig Spool gun setup for AL. Worked awesome.
Ruined a perfectly good jeep.
OCT '13 & OCT '14 YJOTM 2014 YJOTY
Norcal_chris is offline
