Can't shift into any gear!!! - JeepForum.com
post #1 of 8 Old 09-18-2012, 01:13 PM Thread Starter
carloricci1
He clutch has se play and can't shift. Does anyone know if it's the slave cylinder?
carloricci1 is offline
post #2 of 8 Old 09-18-2012, 01:18 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Will it shift when the jeep is off?
Luck Favours The Prepared
Anticanman is offline
post #3 of 8 Old 09-18-2012, 01:21 PM
jaycal3
When i lost my slave on my last jeep I had fluid everywhere underneath and couldnt shift at all... Dont know what you drive so I dont know if its internal or external...
93 YJ, 6 cyl,3.5" BDS,1" Prothane BL,1/2" booms, 33" Mickey Thompson MTZ on MT Beadlocks.
Do your part for Leukemia research - help find a cure.
KCCO
jaycal3 is offline
post #4 of 8 Old 09-18-2012, 01:35 PM Thread Starter
carloricci1
I dont know if I'm replying right, new at this but anyways. Yes it does shift when it's off. That how I got it run on 2nd till I got home. Now the weird thing is that at that time the clutch pedal was pretty low but when I parked it and left it for a fre hrs then it was back up and working
post #5 of 8 Old 09-18-2012, 01:37 PM Thread Starter
carloricci1
93 Wrangler stick shift. No leaks or I havn't seen any so far
post #6 of 8 Old 09-18-2012, 01:41 PM
jokerchief462
Yeah typical wrangler clutch problem. It is losing pressure could be the slave could be the master. Since it is a sealed system it has to leak somewhere. Mine did the hot and cold no work then works a couple days before the leak showed up under the bellhousing. So you need to take a look under the bell housing and the cab where the peddle pushes the piston for the master it will leak down the firewall by the pedal.
jokerchief462 is offline
post #7 of 8 Old 09-18-2012, 01:56 PM Thread Starter
carloricci1
Would air in the lines cause that? Or that has nothing to do with it?
post #8 of 8 Old 09-18-2012, 03:00 PM
WakeDoctor
It could be air in the lines but the question is how did it get there. Probably a leak. You can bleed the system of air with another person, I believe there is a write up on here somewhere, and if it comes back/doesn't fix it you might need a clutch replacement.
WakeDoctor is offline
