Can't shift into 4wd - JeepForum.com
post #1 of 6 Old 12-13-2001, 08:44 AM Thread Starter
bobznew
Last night, a buddy and I got stuck in a pretty bad hole because, at that precise moment, we couldn't get the Jeep ('95 YJ) to shift into 4wd. The 4wd light on the dash would light up, but neither of the front wheels would turn.
Could this be a transfer case problem, and if so, what's the best way to fix this problem?
thanx
'97 ZJ, 4.0L, Gibson Cat-back system, Daily Driver
'95 YJ, 4.0L, 3.5" BDS suspension lift, Boomerang Shackles, BDS Shocks, 33x12.50 TSL's, Lock-Rite in rear, No-Slip up front, Posi-lok, Warn XD9000i winch, and a ton of dried Mississippi mud!
bobznew is offline
post #2 of 6 Old 12-13-2001, 12:55 PM
Kev
Master of the Obvious
Kev's Avatar
Was the front driveline turning? If so, it isn't likely a transfer case problem. If you've been around the forum much, you've probably read about all the trouble with the vaccuum lines and switch on the front axle. I would start there; buy a manual, search in this forum, or find somebody who's worked on YJ's and check out the connections and switch (i can't remember the actual name of it ) that locks the front in 4-wheel drive.
"AN ARMED SOCIETY IS A POLITE SOCIETY"
"We, too, born to freedom, and believing in freedom, are willing to fight to maintain freedom. We and all others who believe as deeply as we do, would rather die on our feet than live on our knees." FDR
Blue Jeep Club Member #4
92 Canyon Blue Wrangler YJ 4.0L - with some fun goodies
Kev is offline
post #3 of 6 Old 12-13-2001, 01:29 PM
Newfie
Chances are, if there was a problem with the t-case, you would know it in 2wd as well. Clicking sounds or knocking right under your butt and you would probably feel vibrations when driving.
Not to sound rude, but are you sure it was in 4wd? Sometimes when you pull it back to 4 low, you can mistake nuetral for it (and the light will still be on). Were the back wheels spinning?
In regards to the vacuum system Scrap it and buy (or fab) a posi-lok kit if you plan to keep the D30 (and not replace the axles with TJ axles). Not worth messing with, too unreliable. HTH
No officer, that wasn't an accident. I did that on purpose...
Newfie is offline
post #4 of 6 Old 12-13-2001, 07:00 PM Thread Starter
bobznew
Are you talking about something like a BDS Rock Lock?
BTW, we nearly stuck a 70HP tractor getting the @#%!* thing out of the mud. We finally had to get a bulldozer to get it out. No winch yet unfortunately.
bobznew is offline
post #5 of 6 Old 12-16-2001, 07:56 AM
dartboy
dartboy's Avatar
Not saying this is how it goes every time but...all the troubles I've had with vaccum lines, the 4x4 light didn't come on. That's just my experiences though.
Jason
90 YJ...Stock for now.
74 Dodge Dart Sport
dartboy is offline
post #6 of 6 Old 12-16-2001, 08:52 PM
Newfie
Same idea, replace the vacuum system with a cable actuated one.
Yeah, been down that road before. I REALLY hate bog/mud, have a twitch anytime I see it on the trail now...
Newfie is offline
Auto wont shift out of park, BRAKE TRANSMISSION SHIFT INTERLOCK MECHANISM seems stuck Rivka TJ Wrangler Technical Forum 19 04-22-2012 09:26 PM
What holds the shift lever onto the transmission shift stub? venturad YJ Wrangler Technical Forum 10 01-19-2010 08:31 AM
Can't Down Shift into 2nd or 1st, but when stopped, it will shift MarkkInNJ YJ Wrangler Technical Forum 8 07-03-2009 10:48 PM
Shift on the fly ??? SnowdogMarc YJ Wrangler Technical Forum 8 11-18-2008 01:15 PM
How to separate upper shift lever from lower shift lever??? rgs112 YJ Wrangler Technical Forum 3 08-11-2008 06:59 PM
