Can't retrieve error codes (91 4.0l) - JeepForum.com
post #1 of 4 Old 02-17-2013, 02:44 PM Thread Starter
idskot
I have a '91 4.0L Automatic. I've been able to get codes from it in the past, and until today I hadn't had a check engine light issue.
2 months ago a yoke strap busted, and since then I've been saving up the money / time to get an 8.8 installed. I started it up today to move it (I've been starting ti up every week or so and letting it idle for about 15 minutes during the same time I start up my boat.) I started it up today, started fine. Drove it the 10 or so feet that it needed to go when I realized the check engine light had stayed on. Any attempt to retrieve failed. (See picture)
I disconnected the battery for about 10 minutes. When I reconnected it, I got error codes (12, 33 -- which are normal) and nothing else. I started and it, again, had no check engine light. I turned it off. Came back to it a few hours later and the check engine light is back on. And, again, any attempt to get the code(s) doesn't work.
Anyone have insight?
https://www.youtube.com/watch?v=EkhuJq2DZCI
EDIT:: From what I can gather, it's running fine. I don't have any of my tools here to test fuel pressure or anything similar. But everything seems to be working..?
idskot is offline
post #2 of 4 Old 02-17-2013, 05:28 PM Thread Starter
idskot
bump
idskot is offline
post #3 of 4 Old 02-17-2013, 07:20 PM Thread Starter
idskot
Night bump?
idskot is offline
post #4 of 4 Old 02-17-2013, 10:03 PM
jokerchief462
Yeah I see what your getting. Try 3 on off and then on and see if it reads. Just a guess I got an 88 no codes but I did a lot of those checks working at AZ.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
