Can REAR Dana 35 4.11 work with FRONT Dana 30 4.10 - JeepForum.com
post #1 of 12 Old 04-03-2006, 06:50 PM Thread Starter
4.2-blackone
Can REAR Dana 35 4.11 work with FRONT Dana 30 4.10?
4.2-blackone is offline
post #2 of 12 Old 04-03-2006, 06:55 PM
dadstoy
Yes it will work
dadstoy is offline
post #3 of 12 Old 04-03-2006, 06:56 PM
bobbert350
bobbert350's Avatar
im thinking yes but i m not postive... i no ur suposto use the same gearing but they r really close
bobbert350 is offline
post #4 of 12 Old 04-03-2006, 06:58 PM
Bob_R
Yes and no, in 1974 in a Dodge Power Wagon, Dodge used a 4:10 for the rear and a 4:09 for the front. It was done this way to compensate for ware. So given those facts one could say it is conceivable. But maybe not practical now-a-days due to the close tolerances that gears are now made, and dealing with what we now travel over offroading. I still say sure, why not.
GROWING OLDER IS MANDATORY, GROWING UP IS OPTIONAL TREAD LIGHTLY
Bob_R is offline
post #5 of 12 Old 04-03-2006, 07:03 PM
bobbert350
bobbert350's Avatar
sorry i take back my previous statement i would not that will work but u will wear everything alot faster
post #6 of 12 Old 04-03-2006, 07:08 PM
yesterdaylight
it should work fine. having a numerically lower ratio in front is actually better than having a numerically lower ratio in the back because in 4wd the front wheels turn (just SLIGHTLY) faster causing a nice pulling along affect. and it helps with steering in 4wd.
Green Jeep Club Member #172
Low Output 4 Cylinder Jeep Club Member # 23
Green 1995 4 Banger
If only my pocket was as green as my Jeep :D
yesterdaylight is offline
post #7 of 12 Old 04-03-2006, 07:35 PM
jipjip
jipjip's Avatar
i have an 8.8 rear w/ 4.10's and a 4cyl d30 up front w/ stock 4.11's. being that you only really use 4wd when the roads are slippy, or for offroading, that small of a difference is not noticeable b/c the wheels are slipping anyway over the uneven terrain....i wouldn't advise any more difference than that, but my setup works just fine
95 yj sahara green w/ spice hard and soft top, bikini top,full steel doors, and 2 piece bestop soft doors,tnt customs front tube fenders w/ 6" flare,warn gas tank skid, skidrow oil pan skid,4.0HO,rear 31 spline 8.8 w/ disc brakes,4.10's and lsd,front HP d30 w/ 4.10's and aussie front locker,ax15,np231j w/ jb conversions ss sye, tom woods custom cv d/s,RE 4.5xd,35" toyo open country m/t's, 1" daystar body lift, warn 9.5ti
jipjip is offline
post #8 of 12 Old 04-03-2006, 07:37 PM
Upstate Chili
Upstate Chili's Avatar
It works on every 4 cylinder 5 speed YJ made.
Upstate Chili is offline
post #9 of 12 Old 04-03-2006, 07:38 PM
CNY
Caught ridin' dirty
Do you live in an area where you will use 4WD on the street?
Will either of these have lockers?
CNY is offline
post #10 of 12 Old 04-03-2006, 08:07 PM
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
any ratio within about 2% variance will work. 3.54/3.55, 4.10/4.11 etc.
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline
post #11 of 12 Old 04-03-2006, 08:09 PM
Tshark299
Tshark299's Avatar
1987 YJ Wrangler
This is true... 4.10/4.11 is how they come from the factory.
- 4.0L, AX-15, NP231, 4.10s: 3.5" BDS, 31" Muds
- Donated drive train to the YJ, Parted out the rest
- Buick 225 V6: Painless Wiring Harness, Warn Overdrive & Hubs, 2" Lift, 31" Muds
Tshark299 is offline
post #12 of 12 Old 04-03-2006, 11:22 PM
cage013
JUST RUN THEM
you will be fine they are off by one hundreth of a ratio
that is nothing. thats like saying that if you have brand new tires on the rear axle and one week old tires on the front axle then it wont work.
dont worry so much run that set up and you will be fine
cage013 is offline
Dana 44 front Dana 35c rear? yghong2204 TJ Wrangler Technical Forum 23 12-30-2009 02:04 PM
Dana 30 Front, Dana 60 Rear???? MMerrick YJ Wrangler Technical Forum 7 01-07-2008 12:51 PM
Dana 30 front and Dana 44 rear robisha2 TJ Wrangler Technical Forum 18 07-31-2007 10:49 AM
Dana 25 front and Dana 41 rear MNKMcNeilly YJ Wrangler Technical Forum 5 02-03-2006 02:13 PM
4:10, 33's, Dana M35 Rear, Dana 30 Front Jeeper-4-Life TJ Wrangler Technical Forum 1 02-10-2004 03:48 PM
