Can I use longer "rear" shackles on the front?
| Truck-Lite's New LED Headlamp Series | NEW! Poison Spyder RockBrawler BFH Bumpers! | Poison Spyder BFH Rear Bumpers |
#1 | |
I have 2 shackle kits: Performance Accessories 0380 and Performance Accessories 2342. 0380 is a 1" lift, rear kit. 2342 is a 1.25" lift, rear kit. I would like to use the 1.25" shackles on the front. I emailed Performance Accessories tech line the following question:
" I have a kit marked 2342 Jeep Wrangler 1 1/4" Rear Shackle kit. It is non-greasable. What is the difference between this and the 1 1/4" front non-greasable shackle? Can I use these on the front? Why/why not? What, in general, is the difference between the front and rear shackles on the YJ?" They answered: "The 0283 shackles for the front have a longer overall length than the 0342. Although the amount of lift is the same, at about 1 1/4", the travel of the springs and shackles is different. Also, the location of the brace in the shackles is different. I would not use the 0342 shackles on the front of your Jeep due to the possibility of binding and restricted travel." I replied asking for pics of the parts and they do not have any. Anyway, my question to you guys (after searching all over the web) is can I use the 1.25" rear shackles on the front successfully? If not, why not? Does anyone have pics of the differences between the front and rear ones? I also have a set of 1" lift shackles that I am going to use on the rear that were made for the rear.Thanks in advance. Also, did anyone switch from regular shackle bushings to greaseable ones? Did you notice a significant difference in any area, ie ride, flex, etc...?
#2 |
Not everbody at once, now. Has anyone ever had front and rear shackles in their hands at the same time? Can anyone recall the difference? Surely this question has been raised before. If I am missing it in my search efforts, please, by all means, give me the link or the specific search terms you used to find it.
Thanks again.
'93 4.0 TJ Flares, 4.11's, Sun Performance CJ-7 sliders, 1" shackles with greasable bushings, D35C Powertrax No-slip, 30x9.50 muds |
#3 |
i just pulled my stock shackles and they are all exactly the same, i replaced them with homemade lift shackles that were all exactly the same, and so far everything seems to be working fine
#4 |
The difference is that the shackles that are made fior the front has the center brace right in the middle and the ones to the rear have the brace further down. The reason they do this so that the shackles could allow moore drop for your rear axel without binding against the frame. Does that help. You could use the ones for back in the front but you cant't use the ones for the front in the back.
1991 2.5L YJ, 4" R.E. lift kit, 1-1/4" Lift shackles, K&N CAI, 4.0 TB w/ bored out intake, 5.0L Ford Mustang fuel injectors, 117A alternator, Ford Taurus electric fan, Rancho steering stabilizer, 8.8 Ford axle, 35x12.5x15 Dunlop Mud Rovers, Smittybuilt Titanium side steps, Smittybilt SRC Front Grille Guard Bumper, Smittybilt Stereo Center console, PIAA 520 Series fog lights, Sylvania Silverstar headlights, 20 gallon fuel tank upgrade & Herculined tub. |
#5 |
that makes sense, i made mine the same for front and rear and havent had problems yet, ill have to see what develops
#6 | |
![]() Your explanation seems to make sense. I will put them on and see what happens. Thanks!
#7 |
I put them on and all seems well. The brace in the middle of the shackle hits the frame a bit and I may trim it eventually, but it doesn't seem too bad. Took them to Tellico and all worked fine.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
