Can I tow 94 YJ with auto trans? - JeepForum.com
post #1 of 8 Old 09-24-2007, 02:22 PM Thread Starter
cropduster
1984 CJ8
Hey guys, pardon my jumping over to your new Jeep forum. A buddy of mine has just bought a real nice 94 YJ and wants to pull it to deer camp. He can't get a straight answer if it's ok to pull it in transfer case neutral. I told him about the forum and said I'd get him a professional answer. It has the straight six with auto transmission. So, what do ya'll think?
Thanks,
barryb
1984 CJ8 w/258 and 4 speed. TFI w/Delco module, propane power, 3" lift
2001 Toyota Tacoma 4WD 6 cylinder
cropduster is offline
post #2 of 8 Old 09-24-2007, 02:36 PM
bobbert350
bobbert350's Avatar
when you put the transfer case in N or neutral it disengages the transfer cas from the drive line...N is for towing
88 jeep wrangler, 4.2, auto---cragar soft 8's, d35 locker, bucket seats with 5 point harnesses, warn bumper w/ grill gaurd, winch plate, kc daylighters, light bar, herc the interrior, rebuilt tranny (yay) with tranny cooler, winch and msd ignition, 3.5 inch fabtech lift, currie boomerang shackles f/r, weber carb...[B]
Why only go anywere fast when you can go anywhere
bobbert350 is offline
post #3 of 8 Old 09-24-2007, 03:50 PM
versoel
2009 JK Wrangler
if you put both the transmission and transfer case in neutral you should be just fine towing it.
versoel is offline
post #4 of 8 Old 09-24-2007, 07:51 PM
GrimJeeper91
GrimJeeper91's Avatar
Incorrect!!! For an automatic the correct way to tow is with the TC in N and the tranny in park.
'91 YJ 4.O, Auto, Rr. D60 w/ 35 Spline Alloy USA Axles & Detriot Locker, Fr. D30 True-Trac, 4.56's, 4.5" Deaver Springs, Bilstein 5100's, 1" BL, Rubi Flares, 35x12.50 MT/R's on MT classic II's, Detroit Locker, Vanco Big Brakes, Booster & Master, Warn 9000XDI, York OBA, AA SYE & TW's DS's, Teraflex Belly Up, Rocker Guards...
GrimJeeper91 is offline
post #5 of 8 Old 09-24-2007, 08:09 PM
coyote_94yj
coyote_94yj's Avatar
x2
You don't want the tranny turning AT ALL, and there could be enough friction in the t-case to turn the tranny if it is in neutral.
Chris
coyote_94yj is offline
post #6 of 8 Old 09-24-2007, 08:28 PM
Weekender1969
100% correct. If you don't believe us call any Jeep stealership and they should tell ya the same. The reason for this is actually rather simple. Since the internals of the Tcase are moving, keeping the input shaft stationary will cause the oil pump in the Tcase to still pump oil to the internals, thus lubricating the gears.
Dale
94YJ SOA on 2.5 OME springs, 35X12.50X15 BFG MT's, 8.8 and lots of armor.
A plug for my clubs project:
Weekender1969 is offline
post #7 of 8 Old 09-27-2007, 05:47 AM Thread Starter
cropduster
1984 CJ8
Thanks y'all. Appreciate the help.
barryb
post #8 of 8 Old 10-01-2007, 09:38 PM
Ryno98
My Jeep's first life was that of a poor slave stuck behind a motorhome. The first owners towed it in T-case N and tranny N -- long story short: the transmission had to be rebuilt at only 60K miles. My only regret is not being smart enough to switch to an auto tranny from an XJ at the time...
1994 YJ, 4.0, auto, only 63K miles, RE 2.5" XD w/ OME shocks, discos, JKS telescoping trackbar, Creager 15X8 soft 8's (4" BS), BFG MT KM 31X10.5X15, SRC Front/Rear bumpers w/ tire carrier
Ryno98 is offline
Is it easy to swap out my 3speed auto trans for the 4speed auto trans? bhicks TJ Wrangler Technical Forum 15 08-30-2010 09:30 AM
00 TJ Auto Trans ? white2000TJ TJ Wrangler Technical Forum 26 01-19-2010 10:59 AM
What Auto Trans in 88 YJ 4.2 Richo YJ Wrangler Technical Forum 2 10-22-2007 04:09 PM
BL With An Auto Trans treehugger TJ Wrangler Technical Forum 11 01-08-2007 08:44 AM
auto trans BIGKURT666 TJ Wrangler Technical Forum 1 01-05-2007 09:02 AM
