can i swap a tj dana 30 intp my yj ? - JeepForum.com
post #1 of 7 Old 06-01-2013, 07:19 PM Thread Starter
Xzero117
If I weld on the leaf spring perches and made some modifications to it ?
Is there any other radical modifications I have to do ? Any write ups out there ?
Its impossible to find a yj dana 30 with 3.73 gears locally yet they're everywhere for tjs
Xzero117 is offline
post #2 of 7 Old 06-01-2013, 07:55 PM
TSEJEEPERS
Yes it would be possible but it would also be a downgrade.
YJs have a high pinion 30 and the TJs have a LP 30.
You may have to shorten or lengthen your driveshaft.
Another option would be one out of a XJ (Cherokee) They are high pinion too.
Lots of those out there and it would probably be cheaper than the TJ 30.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #3 of 7 Old 06-01-2013, 08:33 PM
SeanB95YJ
problem with using a TJ (or XJ, ZJ and pretty much any Jeep newer than 1987) is that they are all coil spring front.
whether you choose to cut off the coil and control arm mounts and weld on spring perches - or keep the coils and convert your YJ to run coils... either way would be a fairly radical modification needed - though modifying the axle would be the lesser of 2 evils, still a bit of work. probably cheaper in the long run to get a YJ D30 and just regear it to the 3.73 gears you're looking for
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #4 of 7 Old 06-01-2013, 09:12 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Originally Posted by Xzero117 View Post
If I weld on the leaf spring perches and made some modifications to it?
Yep.
Is there any other radical modifications I have to do?
None that I'd consider radical.
I have done a few by owners choice. We didn't bother to do a write up on any of them.
Joe Dillard is offline
post #5 of 7 Old 06-01-2013, 09:57 PM
SuperMidget
um... newer than 87 is all coil spring fronts? do you even know what year yj's were made?
SuperMidget is offline
post #6 of 7 Old 06-02-2013, 02:09 AM
fratis
fratis's Avatar
You can't find one because all the TJ guys are swapping them into their jeeps while we are actually swapping in decent upgrades that are actually worth while.
-insert meaningless out-of-place political diatribe-
fratis is offline
post #7 of 7 Old 06-02-2013, 02:15 AM
SeanB95YJ
the OP was asking about using a D30 out of a Jeep OTHER than a YJ because he had trouble finding a YJ axle
swap/build thread:
