Can I swap Liberty wheels onto my YJ? - JeepForum.com
post #1 of 5 Old 12-06-2010, 09:55 AM Thread Starter
CrawlingForward
I keep getting conflicting information here, but after I put on a lift, I'd to go from my stock tire size to 235/85/16 BFG ATs (I love the tall and skinny look)
I love the stock look and don't like the look of the satin black Black Rocks or Cragars, so I was hoping to be able to junkyard or ebay a set of 5 on 4.5 16x7 wheels from a Jeep Liberty or Patriot. There are a lot of other wheels that size out there, but I'd love for them to still say Jeep.
So will (the 16") Patriot or Liberty wheels fit on my '95 YJ? If not, are there any other vehicles that would have donor wheels?
95 YJ, Rio Grande - The Wannabe Sleeper Wheeler
2010 JKU, Islander Edition - The Burly Stock Overlander
Build/Wheel/Break/Educate/Upgrade/Repeat
CrawlingForward is offline
post #2 of 5 Old 12-06-2010, 10:17 AM
Destr0
I have a Patriot and the wheels have a HUGE amount of backspacing so I believe that is where the issue will be. I tried them on my XJ just to see and I do not believe I would have been able to drive without major rubbing issues, and that was with 225/65/17 tires (Pat has 17" wheels).
Not sure on the BS of the Liberty wheels, but if they are the same then it could be an issue unless you want to run wheel spacers.
~K
Destr0 is offline
post #3 of 5 Old 12-06-2010, 02:50 PM Thread Starter
CrawlingForward
Just did a little more research and YJs, Patriots, and Libertys (<--sp?) all have 5 on 4.5 with 5.5 backspacing for an offset of 38mm.
So in theory they would work if you were replacing a tire of the same width. When you go from 215 to 235, that's where I need to figure out if I'll have enough room, I guess.
http://www.jeepforum.com/forum/f9/stock-tj-specifications-452871/#post4131908
Jeep Liberty/Tires & Rims - Wikibooks, collection of open-content textbooks
http://www.jeep/patriot.com/forum/showthread.php?t=1846
(Take out the / in the last link. I have no idea why *********** is censored....)
post #4 of 5 Old 12-06-2010, 03:25 PM Thread Starter
CrawlingForward
More awesome links I have found in my searches (in case someone stumbles upon this later)
http://www.jeepforum.com/forum/f15/b...w-rims-862227/
Wheel / tire size calculator / comparer - RIMSnTIRES.com <-- Soooo awesome
post #5 of 5 Old 12-06-2010, 03:33 PM
giggityjeeper
YES you can, I run my winters on liberty rims, they are 16 VS 15, but bolt patternt is same
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
liberty wheels? airdevil85 YJ Wrangler Technical Forum 0 02-03-2010 12:00 PM
Will Liberty wheels fit LJ popeyesides TJ Wrangler Technical Forum 3 02-15-2009 09:07 AM
07 JK wheels on 02 Liberty reddog76 JK Wrangler Technical Forum 3 10-17-2008 07:38 PM
Liberty wheels on LJ? FXSTCHEWY TJ Wrangler Technical Forum 11 06-18-2007 08:31 PM
