Can I remove? - JeepForum.com
post #1 of 3 Old 06-01-2013, 06:43 AM Thread Starter
Joe100
Can I remove?
Hi! Stupied ? Can I remove the EGR Thats on the intake manifold just below the carb, I made a piece of 1/4" alumn plate to go over the two holes and now it won't start? the egr was not working before I startedand the Jeep ran fine. Thanks for any help. Joe100
Joe100 is offline
post #2 of 3 Old 06-01-2013, 07:14 AM
roadyrob
1987 YJ Wrangler
don't know why it won't start but my EGR has been gone for years. must have knocked some thing loose while working on it.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #3 of 3 Old 06-01-2013, 07:19 AM
coony278
As long as the holes are blocked off independantly from each other it will be fine. But if air can get from one hole to other you have crated a huge vacuum leak.
If the holes are blocked you have another problem as to why it wont crank.
coony278 is offline
