Can I install rear YJ leaf springs in the front of my YJ? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Can I install rear YJ leaf springs in the front of my YJ?
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! *STOP UNWANTED LIGHT BAR NOISE* with Pandemic LED Light BaRuffstuff 10 year sale
Unread 10-06-2009, 06:08 AM   #1
Jeepwood
I'm installing a 2" Add-a-leaf kit on my 94 YJ tomorrow.
I noticed that the rear springs have 5 leafs and the front have only 4 and sit about one inch lower to the ground(due to the weight of the engine, i'm sure).
I have 2 extra pairs of rear (5 leaf) sitting around my house.
So my question is: Can I use my extra 5 leaf springs i have laying around on the front of the jeep, to raise it that extra inch?
Also when i add the AAL 2" spring, can i also add another spring from another pack to give it an additional lift?
Please advise...
PS: I don't care about ride quality or how stiff this may or may not make the ride, this is my winter beater / off road toy?
A JEEP IS LIKE A GOOD WOMAN... I LIKE THEM DIRTY!
Jeepwood is offline   Reply With Quote Quick reply to this message
Unread 10-06-2009, 07:25 AM   #2
fishwater2
When I picked my YJ up the PO had the rears installed in the front, they are the same length & will work without a doubt.
1989 YJ HEEP, 2.5l, 5 speed, D30 4.10, D35 4.10 OX Locker, 33" TrXus MT tires, Superlift 3.5, 1.5" BL
fishwater2 is offline   Reply With Quote Quick reply to this message
Unread 10-06-2009, 08:42 AM   #3
cmsurfer
Yep... When I got my BDS lift, I bought 4 rear spring packs.
cmsurfer is offline   Reply With Quote Quick reply to this message
Unread 10-06-2009, 08:47 AM   #4
muddy93
1987 FSJ Wagoneer
[QUOTE=Jeepwood;8053523]
Please advise... QUOTE]
I'm guessing that you are still spring under? if so, simply adding another spring(unless it has more arch, and a higher spring rate, than your AAL) is going to lower the jeep. granted, it will only lower it the thickness of the spring, but it's still going to lower it.
maroon 1987 Grand Wagoneer. stock for now...
muddy93 is offline   Reply With Quote Quick reply to this message
Unread 10-06-2009, 09:09 AM   #5
YJake
What would be the advantage of this?
I plan to go BDS or OME when I lift.
/l , [____],
l---L--[]lllllll[]-_
()_) ()_)==@=)_)
Originally Posted by clemsonfan16 View Post
The 4banger only whines because it wants more!
Originally Posted by Opihi59 View Post
3 Things to know about the forum: Always PB blaster, Always check the FAQ, Always do a search, and if none of that works, ask Mean Max.
YJake is offline   Reply With Quote Quick reply to this message
Unread 10-06-2009, 12:00 PM   #6
Jeepwood
Yes i am still spring under.
Do you mean lift it?
If you diid mean it will lower it, that why?
Unread 10-06-2009, 12:13 PM   #7
muddy93
1987 FSJ Wagoneer
no, I meant "lower" it.
technically, it would depend on where in the leaf pack that you placed the extra spring. if the extra spring is placed between the main leaf and axle, it will raise the axle in relation to the frame, which will lower the jeep. if the extra spring is placed below the main leaf, it will NOT lower the jeep, but it also will NOT lift it either(with the exception of AAL's which have more arch and spring rate, which basically forces the rest of the springs to have more arch.).
Unread 10-06-2009, 12:18 PM   #8
muddy93
1987 FSJ Wagoneer
ok, this pic should explain it a little better than I can.
basically, with a Spring Under Axle suspension, anything placed between the main leaf and the axle, will lower the vehicle.
anything placed under the main leaf(with the exception of AAL's or other springs that have either more arch, or a higher spring rate), will have no effect on vehicle height.
Unread 10-06-2009, 01:03 PM   #9
cmsurfer
Now that I think of it, I think I have 4 front leaf packs. I believe the extra leaf in the front packs is to help with all the weight from the engine. Running a hardtop and rear tire carrier was sagging my old springs.
Unread 10-06-2009, 01:32 PM   #10
giggityjeeper
one advantage is OME DOES NOT MAKE A HD front spring only a rear, so I bought 4 rear HD springs, or VS versa, they odnt make a HD for front or back so you have to get 2 pairs of the same I cant remember now......but OME you WANT HD, and the BEST spring EVER....WOW FLEX
and like the other guys said adding a leaf to spring under will lower your ride......
Started with some rust repairs ended in a SOA...
http://www.jeepforum.com/forum/f12/h...-jeep-1050879/
family roll bar swap/upgrade..
http://www.jeepforum.com/forum/f12/f...grade-1054753/
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline   Reply With Quote Quick reply to this message
Unread 10-06-2009, 01:37 PM   #11
93jeepyj
That sounds more like it. I had the same thing happen with my springs and I talked to bds about it and they sent me HD springs for the rear which were the same as the springs I already had up front. All of my springs have 5 leaves in them now and it sits level with the hardtop on and and inch higher in back with the soft top on.
93jeepyj is offline   Reply With Quote Quick reply to this message
Unread 10-06-2009, 07:52 PM   #12
Jeepwood
I understand that by adding a block under the axle but over the leaf will lower it, that makes sense.
But for example, if i added my AAL spring plus another stock large spring, for 7 springs in total, the additional stock spring will not have any effect on raising the vehicle, because the spring rate is not any grater than the other factory springs?
So stacking up additional factory springs will not raise the Jeep, only if they had more arch, or a higher spring rate, right?
Unread 10-06-2009, 07:58 PM   #13
93jeepyj
Right but it would ride stiffer and probably have more load capacity with the extra leaves. Some guys will add a main leaf with the eyes cut off from a dakota or maybe an s10 because they have more arch. Im not sure that that would do much for you since you already have the AAL though.
Unread 02-06-2016, 04:55 PM   #14
skipstein
Howdy;
I own a 1991 Wrangler 2.5L 4 banger, that started life with a soft top and now runs a hardtop permanently. I have the stock 'normal duty' suspension. I will be adding a Warn M8000 winch to the front of the Wrangler this spring. I figure that adding 'heavy duty' springs all around will do the trick. I would also like to run 'rear' 6 leaf Crown HD springs on all four corners. As I read the thread, this is OK as the front and rear are the same, eh? I also will be adding new Bilstein shocks and Crown HD shackle kit. Any comments?
Thanks,
Skip
skipstein is offline   Reply With Quote Quick reply to this message
Unread 02-06-2016, 07:23 PM   #15
csmit328
All 4 leafs should be the same. Im not sure if some manufacturers are different but I had some Rubicon Express springs that all had the same part number and ended up getting put on a friends jeep (long story). The Jeep was as level as any other and he said he had no problems putting them on. You should be good but there are others with more experience that can tell you if I am right or not.
csmit328 is online now   Reply With Quote Quick reply to this message
