Can I get some approval on my shopping list? - Page 2 - JeepForum.com
post #16 of 24 Old 07-29-2013, 09:53 PM
DirtKar
I pledge allegiance.
DirtKar's Avatar
Grab a manual as well. It will explain the confusion you will encounter when trying to figure out how the tensioner works.
Here's a cool link that may help you on future projects.
http://www.stu-offroad.com/siteindex.asp
Luck Favours The Prepared
YJOTM JULY 2014
DirtKar is offline
post #17 of 24 Old 07-29-2013, 10:17 PM
rambo3489
Originally Posted by 102joe View Post
damn all those replies while I was typing
Type faster. There was like 20 minutes between the OP and you. Lol
List looks good. You've been told what you need. Now get to work.
Sent from my phone because I'm doing something "more important"
89 YJ.. My first jeep and I won't let it go. ▀||||▀
Current Project: None... I disgust myself.
<a href="
THE YJ MY WAY</a>
rambo3489 is offline
post #18 of 24 Old 07-29-2013, 10:27 PM
jokerchief462
How about new heater hoses while your at it and flush the heater core.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #19 of 24 Old 07-29-2013, 10:46 PM Thread Starter
jhalden
I am considering the heater hoses and heater core flush but to be honest my heater already cranks, gets it hotter than a crackhouse with multiple stoves. What I really need to fix is my AC, but I have gotten used to driving without it and I'm a broke college student. Heard the AC was an expensive and labor intensive procedure.
Thank you everyone all for your support and help! I will do a little research on the heater core flush/new hoses and see if I should just tackle that as well.
jhalden is offline
post #20 of 24 Old 07-30-2013, 12:24 AM
debord97
I use rtv with the gaskets. Put the rtv on the pump and thermo housing, set the gaskets in place and then install. Next time you have to change a part the gasket normally comes of with the old part and no scraping on the block has to be done.
debord97 is offline
post #21 of 24 Old 07-30-2013, 03:21 AM
lutzke21
A way to verify belt tension. Either the actual tool, or use the ruler method.
-Scott
'94 YJ on 35s
M C L M M
lutzke21 is offline
post #22 of 24 Old 07-30-2013, 03:37 PM
jsd1991yj
A reason to flush the heater core and the rest of the system is to clean it out. Sometimes places in the engine and heater core collect "deposits" that can clog up the new radiator.
jsd1991yj is offline
post #23 of 24 Old 07-31-2013, 09:30 PM
Dingo1033
I read early on that you can re-use your hose clamps. I'm sure others cringed as I did when I read that. I learned a long time ago that spending the extra $2 for a couple of clamps is well worth chasing down a leak.
You're a broke college student. Look through the couch cushions and your passed out buddies pockets for the change. KCCO
"I may not change the world, but I'll damn sure leave a scar"
Dingo1033 is offline
post #24 of 24 Old 07-31-2013, 09:42 PM
yellow2kgt
I would suggest getting full strength antifreeze. Its the same price as the pre mixed stuff in my area. It could save you a few bucks as distilled water only runs about 89 cents.
1990 Jeep YJ 4.2
Howell EFI, BDS 3.5" lift, M.O.R.E 5/8" Boomerang shackles, 1" Daystar BL, 1" JKS MML, TFI, Crager soft 8s w 35" Dunlop Mud Rovers, Ford 8.8, 4.88s, Dana 30 E-Locker, Terra Flex SYE, Tom Woods CV shaft, Warn M8000.
yellow2kgt is offline
