Quantcast Can i fit 32X10.50 tires on a 2.5 RE lift? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Can i fit 32X10.50 tires on a 2.5 RE lift?
Truck-Lite's New LED Headlamp SeriesCURRIE TJ/LJ/XJ/MJ HD Steering - Low Price Guarantee!Poison Spyder DeFenders™ - "Tubeless" Jeep Fende
Old 09-27-2006, 08:21 PM   #1
Ryanjeeper
the title pretty much says it all. Im looking at running super swamper tsl radials, how well do these tires wear? and will i have enough flex room and all that?
1990 YJ
Rubicon Express 2.5" Standard Lift
32x11.50 Lemans A/T
Ryanjeeper is offline   Reply With Quote
Old 09-27-2006, 08:51 PM   #2
5.0YJ
you should be ok with 32's with that lift...i had 31x10.50s on a stock jeep with no lift...they rubbed when flexing though.....with 2.5 lift they will clear for the street
5.0YJ is offline   Reply With Quote
Old 09-28-2006, 07:13 AM   #3
Ryanjeeper
anyone else have some imput?
1990 YJ
32x11.50 Lemans A/T
Old 09-28-2006, 08:10 AM   #4
MCJeeper
to make sure you dont rub at full flex you could put TJ flares on that will add about an inch or you could do a one inch body lift.
92 YJ 4.0 I6
01 Suby 2.5RS
MCJeeper is offline   Reply With Quote
Old 09-28-2006, 08:10 AM   #5
SEZARO21
I'm thinking about getting the same lift ad the same size tires. what about if I were to add a 1" BL? would that be enough for the those tires to flex?
1991 2.5L YJ, 4" R.E. lift kit, 1-1/4" Lift shackles, K&N CAI, 4.0 TB w/ bored out intake, 5.0L Ford Mustang fuel injectors, 117A alternator, Ford Taurus electric fan, Rancho steering stabilizer, 8.8 Ford axle, 35x12.5x15 Dunlop Mud Rovers, Smittybuilt Titanium side steps, Smittybilt SRC Front Grille Guard Bumper, Smittybilt Stereo Center console, PIAA 520 Series fog lights, Sylvania Silverstar headlights, 20 gallon fuel tank upgrade & Herculined tub.
SEZARO21 is offline   Reply With Quote
Old 09-28-2006, 08:19 AM   #6
SEZARO21
never mind question already asked?
Old 09-28-2006, 09:16 AM   #7
pezley69
I have the RE 2.5. With 32 inch tires you will rub slightly on full flex. I can put my 31's just barely (and I mean just barely) into the flairs. With TJ flairs or a 1 inch BL you should clear 32's.....
If you stay on the streets you could run 32's all day with no problems without the flairs or BL.
Hope this helps.
05 [B]Black[/B] TJ Rubicon 2" Spring lift, Hella 500's on the windshield, SRC front bumper, SRC rear bumper w/ tire carrier, SRC rocker guards/steps, Mile Marker PE8000 winch
pezley69 is offline   Reply With Quote
Old 09-28-2006, 11:02 AM   #8
viper224
you will be fine i had 35s on with just a 1 inch body until my suspension lift came. i have cutt fenders and i had no rubbing or anything. if you cutt you can fit much much more
viper224 is offline   Reply With Quote
Old 09-28-2006, 03:13 PM   #9
bigpappy
i have the re 2.5" lift kit with 1" lift shackles and i clear 32"x11.50" mud terrains with no problem...even flexing (possibily because i still net at about 5" of lift)
Red '95 YJ auto. 4 banger
SOA, 35s, 30/8.8, 4.56, Locked F/R, custom blah blah.
bigpappy is offline   Reply With Quote
Old 09-28-2006, 03:43 PM   #10
crazymon01
i agree.. u can but u will have some rub at full flex i origionally had the rc 4" lift which basically only 2"lift and it tore my tires up...
I6
ARB snorkle
307 -> 411 gear swap
lock rite locker on the dana 35
33 x 12.50 Mickey Thompson radial MTZ
4.5" Rubicon Express heavy duty Suspension Lift
currie boomerang shackles
8,000 lbs. Winch
bikini top
tonneau cover
pictures?? http://www.cardomain.com/id/ironm98
crazymon01@aol.com
crazymon01 is offline   Reply With Quote
Old 09-30-2006, 04:09 PM   #11
Ryanjeeper
will the tires rubbing in the fender tear them up?
1990 YJ
32x11.50 Lemans A/T
Glock Forum
