can the cold do this ? - JeepForum.com
post #1 of 22 Old 01-07-2014, 10:49 PM Thread Starter
cody413
Hey y'all it's been pretty cold here in Florida ( tell im a Floridian) it hit like 40 last night. AD when I got in my 92 Jeep Wrangler 2.5 this morning states up like normal. But when I got about 100ft down the road in second gear I noticed it was running like ****. It would sputter at 1200 1300 rmp. Once I let it run for a couple of mins it cleared up. I had a similar problem before but it was either my TPS or my temp sensor (both changed at once ) and it clustering right up. Also did the 5.0 injectors as well made a difference. Idk if the cold would the cold would make it run like that but it's not as cold as up north.any help would be appreciated
cody413 is offline
post #2 of 22 Old 01-07-2014, 10:57 PM
jokerchief462
Yes even fuel injection takes a minute or two to run smooth in the cold. My F150 dies it my YJ does it here in Vegas when we get into the thirties overnight.
Sent from underneath my Jeep
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #3 of 22 Old 01-08-2014, 12:44 AM
fratis
fratis's Avatar
I know how crappy that can be. I think it actually got down into the mid 60s here last night.
-insert meaningless out-of-place political diatribe-
fratis is offline
post #4 of 22 Old 01-08-2014, 01:31 AM
Gage56
oh you poor people i dont know what i would do if the temps ever got that low around here
and to think last night it was -6 deg
1992 YJ
Gage56 is offline
post #5 of 22 Old 01-08-2014, 04:47 AM
OldSkull75
It's been so cold here in Kentucky that my jeeps doors actually froze shut Inside my closed a garage. I pulled the half door open and ripped the weather seal right off the door lol.
OldSkull75 is offline
post #6 of 22 Old 01-08-2014, 05:47 AM
superj
we had "feels like" 27 according to the weather channel. my jeep starts right up though, perfectly. carbs are good for that, its the running well after it starts that takes a while in the cold. about 7 or 8 minutes of driving and it acts normal but if you try to take off quickly in those first 7 or so minutes, it bucks and kicks like crazy
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #7 of 22 Old 01-08-2014, 06:39 AM
EABiker
Many southern states do not get the same winter blend gas that the northern folks get, so when it does get cold, the gas will not vaporize as easily as usual in a cold engine.
EABiker is offline
post #8 of 22 Old 01-08-2014, 07:42 AM
Que89YJ
-16 yesterday morning. Look at you intake air temp sensor.
Que89YJ is offline
post #9 of 22 Old 01-08-2014, 07:56 AM
Peety
I wold think that in Fl. the temperature of the plugs would lean more towards the "Hot" end of the scale because of the higher median temps found throughout the year. This would absolutely cause some runability issues, at least during warm up.
Peety is offline
post #10 of 22 Old 01-08-2014, 09:27 AM Thread Starter
cody413
So this is normal ? I just changed both temp sensors not long ago
cody413 is offline
post #11 of 22 Old 01-08-2014, 09:45 AM
Que89YJ
No, then I really doubt it. Check your codes and post back. I believe the problem is air fuel but there are a few possibilities.
http://www.jeepforum.com/forum/f12/h...codes-1257145/
Que89YJ is offline
post #12 of 22 Old 01-08-2014, 09:46 AM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
If this issue goes away when the air temp. does warm up EABiker probably hit the nail on the head.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #13 of 22 Old 01-08-2014, 10:22 AM Thread Starter
cody413
I had to go to the store and I let it start and sit for like 5 min and didn't have a problem. And it's still 50 degrees. Think she just needed to get a lil warmed up first
cody413 is offline
post #14 of 22 Old 01-08-2014, 10:33 AM
Que89YJ
Check your codes.
Que89YJ is offline
post #15 of 22 Old 01-08-2014, 12:47 PM
Mambo_Dave
All I can say is - my timing for putting in a new thermostat into the new-to-me YJ (that didn't have one in it) couldn't have been more timely with this cold weather. It was like one day before the cold came
Still don't have any heat in it - heater core isn't hooked up either... but for the health of the engine I'm so glad I took the time to put a thermostat in it.
Mambo_Dave is offline
cold , sputtering
