can anyone tell me what these wires are??? - JeepForum.com
post #1 of 15 Old 09-10-2011, 05:48 PM Thread Starter
hollybygolly
The other day I was cruising down the road and smelled burning wires... I assumed it was my wipers (the motor goes bad every 6-8 months) so I pulled over and went to disconnect the wires under the dash and discovered these wires were the ones that were burning hot. I disconnected them and everything seems to be functional. What is the world are they for???
hollybygolly is offline
post #2 of 15 Old 09-10-2011, 06:14 PM
ROWA
ROWA's Avatar
The one in the middle looks like the brake switch plug, the one on the right is your steering column plug. I don't know what the left one is.
Good luck and check the wiper wiring for a short you shouldn't have to replace your wiper motor that often. I would look in the wiper switch for a short.
94 YJ Sahara
The best Engineering is no match against natural Stupidity.
ROWA is offline
post #3 of 15 Old 09-10-2011, 06:50 PM
bft89yj
does everything work and drive with out them
not so stock 89 yj on 35s
bft89yj is offline
post #4 of 15 Old 09-11-2011, 06:25 AM Thread Starter
hollybygolly
Everything appears to be functional (except for my wipers... I disconnected those... that's the wire you see at the tip of my index finger). I've had to replace the motor that often because I've had a nasty dash leak. I FINALLY found the source and fixed the leak but the damage was already done. I'm just not sure what the wires in my hand above go to. I thought they went to my dash but everything is as it should be.
post #5 of 15 Old 09-11-2011, 06:31 AM
TSEJEEPERS
On mine those are for the wiper.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #6 of 15 Old 09-11-2011, 06:44 AM
mrmark
Go to this link for your dash leak, it tells where most all leaks come from, helped me fix mine.
http://www.jeepforum.com/forum/f12/t...up-how-628941/
Wave as you pass me :D
The problems of owning 2 Jeeps ... I never know which one to work on or which YJ gets the next mod ...
mrmark is offline
post #7 of 15 Old 09-11-2011, 08:56 AM
sbsg2005
that's the wiring for your wiper switch. the right side runs up into the column, the left runs either to the wiper module, or the motor depending on which wiper system you have.
sbsg2005 is offline
post #8 of 15 Old 09-11-2011, 01:00 PM Thread Starter
hollybygolly
The wires that are in my hand above are not for my wipers. The wires that are detached from each other with black connectors just above my thumb and pointer finger are for my wipers...
post #9 of 15 Old 09-11-2011, 01:32 PM
Fin_Reaper
They look like the connectors for the intermittent wiper module. I'll post a pic of mine shortly.
88 YJ with stuff
Fin_Reaper is offline
post #10 of 15 Old 09-11-2011, 02:25 PM
copleydad
copleydad's Avatar
x2
'89 Islander 4.2l 5 speed
'14 Grand Cherokee Limited 3.6
One Jeep is Never Enough
copleydad is offline
post #11 of 15 Old 09-11-2011, 03:12 PM
alilredjeep
alilredjeep's Avatar
Below is a pic of a wiper intermitent module.
The gray plug in your hand looks very similiar to what is connected to the intermitent module pic below and also...when I googled the number on the wire ribbon (3077) I came up with a multi function switch topic from a few years back.
Visit that link and note that there apparently are two different part numbers noted and do a bit of research to make sure a P.O. hasn't substituted one for the other.
Good luck!
http://www.jeepforum.com/forum/f12/p...-95-yj-330872/
Eddie
RED JEEP CLUB MEMBER #92
'92 WRANGLER, 2.5 Litre, 5 Speed, Rag Top, Superwinch LP8500, Cepek 130W Driving Lights, 31x10.50/AT with no lift, Of course! It rubs!
alilredjeep is offline
post #12 of 15 Old 09-12-2011, 04:16 AM Thread Starter
hollybygolly
I've owned this jeep for nearly 10 years so I'm not sure if the PO changed any of the wires. It would make sense though... my intermittent wipers haven't worked... ever. The only speeds I have are fast faster and the manual one at a time. Years ago my dad replaced some switch and he said he'd never do it again... apparently it was a pain. This ol jeep is a electrical nightmare. I'd love to take it to somewhere and just have them rewire the entire darn thing.
post #13 of 15 Old 09-12-2011, 02:50 PM
tdewit
Your intermittent wipers won't work. You need the "black box" that goes in between the big male and female plug.
tdewit is offline
post #14 of 15 Old 09-12-2011, 04:20 PM Thread Starter
hollybygolly
I do? Huh.... you learn something new every day lol to the junk yard I go!
post #15 of 15 Old 09-14-2011, 10:34 PM
JWELK
The wires in your hand(s) are for the wipers. normally an intermittent wiper module goes between them. I've seen them on ebay for 6 bucks or so. New they are 55 to 60. Someone has rewired something using the black plug above your thumb. That is a Molex plug not an OEM plug.
Regards,
Jim W.
JWELK is offline
LED front signals, 3 wires to 2 wires PurpleTJ TJ Wrangler Technical Forum 2 05-23-2011 03:32 PM
Wires were do they go? zekthecat YJ Wrangler Technical Forum 14 02-03-2009 11:36 PM
Where do the wires go?! FourbyFour TJ Wrangler Technical Forum 2 09-24-2006 08:24 AM
HEI wires Ovenman YJ Wrangler Technical Forum 1 12-23-2005 02:08 PM
Why are there four wires......... BeatAChevy289 YJ Wrangler Technical Forum 4 11-27-2004 08:15 PM
