Can anyone explain what shackles are and how they are installed?? - JeepForum.com
post #1 of 7 Old 04-05-2002, 03:50 PM Thread Starter
Plink
Plink's Avatar
Anyone?
87 YJ 4.2
2" BL, 2" Shackle, 1.5" Black Diamond and Junk
31 MTRs on MOABs
Need new front and rear bumpers
HAM: KB3JQS
Plink is offline
post #2 of 7 Old 04-05-2002, 03:58 PM
V8wrangler_idaho
if you look on your leaf springs on your jeep. one side is connected right to the frame. and the other side has a peice that comes down from the frame and connects to the spring. that peice is the shackel. On the front of your jeep it will be right on the very front of your leaf spring. they are very easy to install on the frount of the jeep the back are a bit more tricky. frount of the jeep you just lift it off the ground and undo the bolts that hold the shackel to the spring and the frame and then take the shakel off and put on the new one. on the back you will probley have to cut the bolts off the shackel on the top of the shackel that connect to the frame. they are too close to the gas tank to pull them out. so just cut them and replace the bolt no big deal. I did a shackle lift on my jeep in about 2 hours. pretty simple. the hardest thing to do was getting the bolts off the back shackel tell i decited to cut them off. problem solved
Daniel Mclay
93 wrangler 8 inch SOA SRS suspention lift 35/12.50 Mt. efi 350 700r4 tranny np 205 t case dana 44s front and rear. lots of extras.
V8wrangler_idaho is offline
post #3 of 7 Old 04-05-2002, 04:23 PM Thread Starter
Plink
Plink's Avatar
Cool I plan on putting on some 31x10.5 and maybe a shackle lift around 2". Should I plan on getting new shocks to fit the lift??
87 YJ 4.2
31 MTRs on MOABs
HAM: KB3JQS
Plink is offline
post #4 of 7 Old 04-05-2002, 04:36 PM
MusicMaverick
MusicMaverick's Avatar
2014 JK Wrangler
no, but wait till you get your tires to put the shackle lift in. Alot of people will say 2" is too much and anything over 1" is too much. I am in the same boat you are in. I have the 31's in my garage, waiting for the rims i ordered to come in. Should be in on monday. I'll let you know how everything turns out but if I dont really see a need to get shackles I might just skip it all together.
Currently: '14 JKU
Past vehicles: '92 YJ, '97 TJ, '10 JK
MusicMaverick is offline
post #5 of 7 Old 04-05-2002, 04:47 PM
V8wrangler_idaho
if you go with a 2 inch lift that would be about a 3 inch longer shackel and thats probley to much. the place that you would notice the diffrence is when you are climbing hills. The frount of the jeep will fill like it raises alot. feels like your floating. I would only go with a 1 1/2 shackel lift. and new shocks wouldn't hurt
Daniel Mclay
post #6 of 7 Old 04-05-2002, 05:13 PM Thread Starter
Plink
Plink's Avatar
What I'll probably do is just throw the 31s on and see how the thing runs. If I have some rubbing I'll look into a 2" suspension lift and skip the shackles all together.
87 YJ 4.2
31 MTRs on MOABs
HAM: KB3JQS
Plink is offline
post #7 of 7 Old 04-05-2002, 06:30 PM
JeepBeep
Best to just get it done the right way and go with the suspension lift. Would have to say anything more then 1" would be hokey. You only paid 50$ for your Jeep? Where did you find that Discount Market?
'01 XJ BONE STOCK (Not for Looong)
'95 YJ 2.5L 3" Sus.
ProComp MT 33s"
JeepBeep is offline
Any pics of rear lift shackles installed (or tips too) drew2000 YJ Wrangler Technical Forum 2 06-13-2006 05:36 AM
Boomerang Shackles installed in the front. BackRoadJPin YJ Wrangler Technical Forum 2 06-12-2006 10:51 PM
Installed shackles and now kopps94 YJ Wrangler Technical Forum 6 03-12-2006 11:26 AM
1" Lift Shackles Installed CanukYJ YJ Wrangler Technical Forum 33 10-14-2004 07:52 PM
just installed con-ferr shackles, mini review socalchef YJ Wrangler Technical Forum 0 07-13-2003 03:54 AM
