Can anyone explain this pic to me - JeepForum.com
post #1 of 17 Old 11-04-2011, 08:44 PM Thread Starter
Mark455SD
1961 CJ5
I'm trying to figure out what happened here.
Mark455SD is offline
post #2 of 17 Old 11-04-2011, 08:49 PM
94chb
a red jeep tried to climb the rock and failed
94chb is offline
post #3 of 17 Old 11-04-2011, 08:52 PM Thread Starter
Mark455SD
1961 CJ5
Is he being held by a winch?? How did he even make it to that point.
post #4 of 17 Old 11-04-2011, 08:55 PM
panaceabeachbum
I'd like to see the next few frames
panaceabeachbum is offline
post #5 of 17 Old 11-04-2011, 08:57 PM
comancheklein
the jeep saw a mouse...my mom does the same thing
2012 jku, manual,D30/D44, stock suspension
comancheklein is offline
post #6 of 17 Old 11-04-2011, 09:01 PM
nathanninja
It looks like an "About to fail..." moment. Based on the fact that the driver is looking out his window at the rear of the Jeep, I'm thinking he might be tied down in the front. Personally my first instinct when I felt myself falling backwards wouldn't be to stick my head out the side. Looks like maybe he went to climb the rock in front, went up at too steep of an angle and started to lean back. Also, the position that the picture was taken from makes it very hard to determine the angle that the Jeep is really at, he may not be quite as vertical as it looks, although it does look pretty bad.
nathanninja is offline
post #7 of 17 Old 11-04-2011, 09:01 PM
pariah24
Yeah, someone was about to have a real bad day. Looks like he came up to the lip too fast and as the Jeep went up, the rear wheel spin caused it to come over backwards. But I could be wrong.
pariah24 is offline
post #8 of 17 Old 11-04-2011, 09:05 PM
94chb
you are, the jeep had to much helium in the front tires
94chb is offline
post #9 of 17 Old 11-04-2011, 10:10 PM
jbolty
jbolty's Avatar
Guess you don't see much rock crawling in NYC.
Pretty common for a jeep to torque over backward because of the short wheelbase. Some guys put a small atv style winch on the front axle to compress the springs in that situation.
http://www.stu-offroad.com/suspension/sdw/sdw-1.htm
jbolty is offline
post #10 of 17 Old 11-04-2011, 10:14 PM
pariah24
See? Should've been running nitrogen in them tires. I also gained 5hp and 7ft/lbs of torque by switching from air.
pariah24 is offline
post #11 of 17 Old 11-04-2011, 10:18 PM
SunDevilJeeper
That's when you crank it into reverse and tap the throttle a little.
Better than doing what that guy did in the video.
1991 YJ: Daily Driver
1992 YJ: Pile of crap sitting in the garage.
SunDevilJeeper is offline
post #12 of 17 Old 11-04-2011, 10:20 PM Thread Starter
Mark455SD
1961 CJ5
I guess you're right.
post #13 of 17 Old 11-04-2011, 10:27 PM
ThatJeepGuy
I think he is past vertical. Not looking out the window but falling due to gravity. Too steep. This actually looks pretty simple. Big lift short wheel base steep hill big flop.
93YJ / 4'' lift / 33'' mtzs / aussie locker in hpd30 / pos d35 in rear(for now) / xrc rock sliders & rear xrc tube fenders tj style/ AJ's offroad rear bumper and tire carrier / LP10000 Superwinch / SQUARE HEADLIGHTS
No farms no food
ThatJeepGuy is offline
post #14 of 17 Old 11-04-2011, 11:44 PM
SnowYJ
1988 MJ Comanche
Ummm..
SnowYJ is offline
post #15 of 17 Old 11-05-2011, 02:23 AM
wickedoffroad
1987 YJ Wrangler
I think all his blinker fluid ran to the rear causing the balance to shift back too far.
wickedoffroad is offline
Somebody please explain this to me bbl32 YJ Wrangler Technical Forum 5 11-27-2010 07:32 PM
Some please explain! VikesTJman TJ Wrangler Technical Forum 8 11-28-2009 10:19 PM
Can someone explain this please! PatrickBateman JK Wrangler Technical Forum 11 02-07-2007 08:05 AM
Would someone please explain XD40TJ TJ Wrangler Technical Forum 6 12-06-2006 07:52 PM
please explain.. kidw/yj YJ Wrangler Technical Forum 25 01-26-2005 04:21 PM
