Quantcast Can a 4.0 timing chain set be used on a 4.2? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Can a 4.0 timing chain set be used on a 4.2?
Poison Spyder BFH Rear BumpersFront and rear Drive shafts @ free shippingPoison Spyder February Special: FREE Rubber Liners when yo
Old 05-14-2007, 08:44 PM   #1
rollerized
Tried a search but found nothing. I have a double roller set for a 4.0 (mopar part #p5249519) and want to put it on my 258 4.2 engine. Do they use the same timing set? Thanks
rollerized is offline   Reply With Quote
Old 05-14-2007, 08:49 PM   #2
mp3coupe
I'm showing different part numbers.
Hit advanceautoparts.com or napa site and search for 90 4.2 and 91 4.0 you'll see different part numbers
mp3coupe is offline   Reply With Quote
Old 05-14-2007, 08:51 PM   #3
4.7stroker
4.7stroker's Avatar
I believe they have a different tooth count.
That said the ratio should stay the same.
When I built my stroker I used the 4.0 timing set on the 4.2 crank, everything went together just fine.
My informed guess is yes it should work.
Dwayne
4.7stroker is offline   Reply With Quote
Old 05-14-2007, 11:11 PM   #4
Ares
Hmm, i was going to guess that the chains may be different widths, but based off 4.7stroker's comment, I guess not.
Other then that and maybe a difference in tooth count i dont see how else they could be different
- Cameron
Axle Information Thread
Oil Filter Study
Ares is offline   Reply With Quote
Old 05-15-2007, 08:18 PM   #5
rollerized
Thanks guys, ya I saw that they had different part #'s but figured it might still work.
Old 05-15-2007, 08:55 PM   #6
Chile99
I called Cloyes and bought a dual roller set when building my 4.6 stroker , they said the same set fit both 4.2 and 4.0 HO. As 4.7 stroker said "used a 4.2 crank and 4.0 cam and it worked".
John
99TJ 4.0 Auto, Lifted and Locked with a lot of Junk
94 yj 4.6 Stroker, 14Bolt, HP44, 101 wheelbase
I brake for Junk Yards
Chile99 is offline   Reply With Quote
Glock Forum
