Quantcast Can 31x10.50's fit on 15x7 rims? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Can 31x10.50's fit on 15x7 rims?
RUBICON EXPRESS Lift Kits and Accessories Available at BasSpartan Lockers FREE SHIPPING Excellent PricesFree Shipping on TIRES at KrawlOff-Road
Old 06-21-2005, 11:42 AM   #1
Sabreman
2005 WK
My '89 Islander should arrive Thursday and I know it's going to need tires. I have the stock steel rims that I think are 15x7. The guy at the tire store said 31x10.50 size tires need a 15x8 rim or the middle of the new tire will wear faster than the rest. Anyone have any comments or experience with this? Thanks.
Where can you get a set of cheap steel rims?
Sabreman is offline   Reply With Quote
Old 06-21-2005, 11:45 AM   #2
ecvjohn
You can do it but the tire store is correct. The tire will balloon out and wear the center, you can play with the air pressure to compensate a bit at the cost of MPG.
95 Wrangler- Stock for now
99 Ram quad cab
ecvjohn is offline   Reply With Quote
Old 06-21-2005, 11:47 AM   #3
cueball
i havent had a problem with mine and i have 32.5 x 11.5 on 7" rims.. at about 30 psi.. my tires are wearing evenly..
i didnt go with a 15x8 because i didnt want to have to buy new rims and fender flares (due to the backspacing.
Bye to the old - 1988 6 cyl 5 speed with a 94 rollbar, tomken 2x4 rocker skids and homebrewed OBA.
Hello to the New - 1999 TJ Sport 4.0L auto.. stock for now
cueball is offline   Reply With Quote
Old 06-21-2005, 11:57 AM   #4
otisdog
I run 33x10.50's on my stock 7" steel wheels. Run them at 30 psi and have no problems. Got about 16k on them. This is on a TJ though.
Jim
03 Sport
otisdog is offline   Reply With Quote
Old 06-21-2005, 01:34 PM   #5
Prospect62
Junior Member
15x7
Same here - have 31x10.50 mud tires on the factory 15x7 rims with no problems in that regard. Some rubbing, but no wear problems to speak of.
Prospect62 is offline   Reply With Quote
Old 06-21-2005, 03:15 PM   #6
RealJeep
exactly you wil have no problem whatsoever
1992 Wrangler Sahara, 4.0L HO, Dynomax exhaust, Kc daylighters, 4" pro comp suspension lift, 33x12.50 BFG MT's, 15x10 rockcrawlers, hurst shifter, Off-road bumpers, SYE, 2-10's, MM 8000 Winch, ARB Snorkel, MORE Boomerangs, CB
RealJeep is offline   Reply With Quote
Old 06-21-2005, 04:38 PM   #7
ufatbastehd
I just got some 31x10.5's and had them installed an my 15x7 rim. no probs yet.
I was informed by "those in the know" on another forum that this would not be a prob.
SOLD-91 YJ AX-15, 4.10 gears, 3.5 bds lift, 1" BL, Tom Wood SYE, 33x12.5 x 15 M.O.R.E Torsion rubber MM's8.8 rear BFG AT KOs on Cragar steelies-blah blah
2002 Liberty LTD-Only 28,000 miles Garage Kept, Like New. Wanna buy it? MMAO
98 Honda Civic EX
ufatbastehd is offline   Reply With Quote
Old 06-21-2005, 09:15 PM   #8
Sabreman
2005 WK
Thanks everyone. Glad to hear that my stock rims will work. More $$ to put towards a lift.
Old 06-21-2005, 09:26 PM   #9
mYJ
After you get them mounted just to the chalk test on 'em (where you put a thick line across the tread and roll 'em over asphalt a couple of times to see where you are riding on your tires) to find the right air pressure and you'll be fine.
-Jeffrey-
[SIZE=1]92 YJ 2.5, OME, Flat Fendered, 31" Big O XTs, Crager Soft 8s, Posi-Lok, no sway/track bars, Exide Orbital, K&N, 4.0 TB & TBS, Mopar Performance Cam, Glass pack & Hi-Flow cat, Grant GT Removable Wheel, Tuffy Console, Other Stuff.[/SIZE]
[FONT=Impact][SIZE=2]Black JeepClub V2.0 #33[/SIZE] [/FONT][FONT=Tahoma] - Me & Roy[/FONT]
mYJ is offline   Reply With Quote
Glock Forum
